Старый 16.07.2015, 00:12   #1
emeadaxsupport: Authorize.Net is changing the URL for submitting credit card transactions
Источник: http://blogs.msdn.com/b/axsupport/ar...nsactions.aspx
Authorize.Net issued an email to all Authorize.Net developers notifying us that they are changing the way that you access the Authorize.Net service. This will only affect Dynamics AX2009 users that are still using the Authorize.Net credit card interface. Please read the complete details at the Authorize.Net notice below:
http://app.payment.authorize.net/e/e...abb994d7435b1e
To change your settings, modify the URL on the Credit Card Processors form to conform to the new settings listed in their notice in the section entitled “Updating your solution”.
The old setting was https://secure.authorize.net/gateway/transact.dll.
The new setting would be https://secure2.authorize.net/gateway/transact.dll.
Note that, according to Authorize.Net's notice, you can make the change immediately. We recommend that you make the change as soon as possible and test the new URL before the older URL no longer works starting in June 2016.
emeadaxsupport: AX for Retail POS Credit Card Authorization is failing with the error: "The authorization could not be completed, Error code: InvalidExpirationDate" Blog bot DAX Blogs 0 17.09.2013 20:11
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
dynamicsaxtraining: Purchase Blog bot DAX Blogs 0 11.03.2012 05:25
Dianne Siebold: Import Credit Card Transactions for Expense Mgmt Blog bot DAX Blogs 0 19.12.2008 10:05
Часовой пояс GMT +3, время: 19:02.
