organicax: Field ‘Contact Id’ must be filled in when assigning a campaign to a source code
Источник: https://organicax.com/2016/07/22/fie...a-source-code/
============== When you are setting up a catalog for a call center and you are going to use source codes. A source code can be associated with a campaign. If you get an error when trying to do this something to the effect “field ‘Contact Id’ must be filled in” then you need to make sure you have a contact for the customer. Here is a quick overview. AX2012 R3 CU10. Cheers Lachlan Filed under: Retail, Sales and marketing ![]() Источник: https://organicax.com/2016/07/22/fie...a-source-code/
