Старый 10.08.2016, 09:11   #1
palleagermark: Public members vs. Parm methods on classes extending SysAttribute in AX 7
Источник: http://www.agermark.com/2016/08/publ...ethods-on.html
I thought I did the right thing when I changed attribute classes that I moved into AX 7 from AX 2012, so they had public members instead of Parm methods.
Well, don't do that. As it turns out the attribute framework is looking for the Parm methods when trying to apply the member values. If you don't have them, the values are not being set.
Hopefully this information can save you an hour or so of tedious debugging.
Старый 10.08.2016, 10:10   #2
Lemming is offline
Lemming
Аватар для Lemming
1,144 / 343 (14) ++++++
Рекомендую почитать эту заметку всем, кто переходит или собирается внедрять AX7 и обрадовался, что parm-методы можно не писать там, где нам не нужны properties
parm-метод, properties
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
axsa: MDM Adapter - Extending Dynamics AX 2012 R3 Master Data Management Blog bot DAX Blogs 0 22.05.2014 03:28
kamalblogs: Data methods in Ax Reports and SSRS Reports Blog bot DAX Blogs 0 22.12.2010 12:11
semanticax: Dynamics AX 2009 Installation - Application Blog bot DAX Blogs 0 22.12.2010 08:11
Часовой пояс GMT +3, время: 00:42.
