Старый 18.09.2016, 04:14   #1
organicax: Counting group – Counting Code – Minimum
Источник: https://organicax.com/2016/09/17/cou...-code-minimum/
As a counting strategy you might want to look at items that reach minimum stock because there has been some movement of them and once they get to a small amount there should be less work in counting then. When setting up your counting groups you can specify a counting code of minimum. This can be used to filter the items that are at or below the minimum.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Supply chain planning, Warehouse management
organicax: Counting group – Counting Code – Zero in stock Blog bot DAX Blogs 0 17.09.2016 21:14
organicax: Buyer group on the planned order Blog bot DAX Blogs 0 17.09.2016 01:16
Поставщик Учетная Группа anatol33 NAV: Программирование 9 25.05.2009 22:17
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 04:29.
