Старый 19.01.2018, 12:11   #1
alirazazaidi: How to apply application hot fix on Dynamics 365 for finance and operations
Источник: https://www.tech.alirazazaidi.com/ho...nd-operations/
Hi a couple of days ago, I got chance to apply application hot fixes required to apply on cloud dev environment.
So I made this very short post.
First Step:
Check in all changes in TFS and make sure no error in AOT.
Second step:
You need to download hot fix from LCS.
Third Step:
To download vm RDP file and credential from LCS and login in VM.
Fourth step:
Open visual studio with run as admin.
Then from Dynamics 365 menu click on addins and from contex menu click on hot fix.
fifth Step:
Extract the zip file and extract the hot fix file and load into dialog. Also set TFS settings.
Apply And in couple of second patch is applied
Sixth Step:
After path applied, Synchronization database from Dynamics 365 menu.
Seventh Step:
Check all compile model, Make sure that all models are check in.
Eighth Step:
Resolve error in the case errors occurs,
In my case no error occurs.
9th step:
Check in everything into TFS with hot fix name in comments.
survivingcrm: What’s An “App” in Dynamics 365 Anyway? Blog bot Dynamics CRM: Blogs 0 06.01.2018 22:14
jaestevan: Microsoft Dynamics 365 for Operations Blog bot DAX Blogs 0 02.11.2016 01:11
NAV Team: How to: Set up your Microsoft Dynamics NAV installation for Single Sign-on with Office 365 using Windows PowerShell Blog bot Dynamics CRM: Blogs 0 19.12.2013 15:10
Platform updates overview - 3.70.B - NAV2009 R2 Blog bot Dynamics CRM: Blogs 0 07.02.2011 22:06
Часовой пояс GMT +3, время: 19:58.
