Старый 19.01.2024, 20:18   #1
ax.docentric: Comment on Configure SharePoint Online integration in D365FO OneBox by Justas
Источник: https://ax.docentric.com/configure-s...#comment-12267
Thank you for this article. It is very useful.Couple things or problems: Connect-MsolService is not working with MFA I did this steps with Connect-AzAccount and New-AzADAppCredential As alternative I think you can just go to your Azure Application and upload Certificate there I did not generate Certificate manually, I used MS provided script "Generate Self-Signed Certificates" And then used "aadclient-onebox-locator1-dynamics-com" certificate Issue I still have: When testing sharepoint connection I got this info: "You are not authorized to connect to '<SomeName>.sharepoint.com'" EventViewer shows me this: ComponentName SharePointHelper Operation VerifyAuthentication httpStatusCode 401 responseHeaders {"x-ms-diagnostics":"3005004;reason=\"The token does not contain valid algorithm in header.\";category=\"invalid_client\"","sprequestguid":"<Some GIUD>","request-id":"<Some GUID>","date":"Fri, 19 Jan 2024 12:00:46 GMT"} Do application need to have some additional permissions to sharepoint?
ax.docentric: Comment on Configure a safe connection to D365FO in OneBox by Sami Blog bot DAX Blogs 0 31.10.2020 03:16
Microsoft Dynamics CRM Team Blog: Impact of Dynamics CRM December 2012 Service Update and SharePoint Online Service Update on CRM-SharePoint Integration Blog bot Dynamics CRM: Blogs 0 09.01.2013 01:11
Часовой пояс GMT +3, время: 01:34.
