Старый 04.11.2010, 12:22   #1
ist is offline
ist
How to hide enum elements?
Hi guys,
Is there any way an element of enum be hidden except through configuration key?
Regards,
ist.
Старый 04.11.2010, 14:14   #2
Ievgenii is offline
Ievgenii
Аватар для Ievgenii
111 / 113 (4) +++++
Nope, AFAIK - it's a the only option available, if you want to avoid coding.
Thx,
Ievgenii Korovin| Dynamics Ax SCM| Microsoft Corp| http://blogs.msdn.com/DynamicsAxSCM/
Старый 04.11.2010, 14:50   #3
ist is offline
ist
I don't want to avoid coding, but I don't know how to do that!
Старый 04.11.2010, 17:37   #4
greench is offline
greench
425 / 74 (3) ++++
http://kashperuk.blogspot.com/2008/0...lowing-to.html
or use the fill a temporary table in the method lookup
Последний раз редактировалось greench; 04.11.2010 в 17:39.
За это сообщение автора поблагодарили: kvg6 (3).
Старый 04.11.2010, 19:16   #5
ist is offline
ist
Thanks a lot.
Старый 04.11.2010, 20:23   #6
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,300 / 3533 (124) ++++++++++
In EE-localization (AX 4.0 SP2 EE) exists class EnumLookup_RU (Form EnumLookupForm_RU) which shows enum elements passed in class by container (empty container = all elements)
emeadaxsupport: How to set up Dynamics AX 4.0 Reporting role on application with Turkish GLS installed and collation Turkish_CI_AS Blog bot DAX Blogs 0 04.08.2010 00:06
emeadaxsupport: How can the Role Center be individually turned off? Blog bot DAX Blogs 0 14.07.2010 01:05
emeadaxsupport: How to hide the Navigation Pane in AX 2009 Blog bot DAX Blogs 0 30.06.2010 21:05
axcoder: How to hide Content Pane in Ax 2009 Blog bot DAX Blogs 0 02.07.2008 00:07
Arijit Basu: Elements changed between versions of Microsoft Dynamics AX Blog bot DAX Blogs 0 12.04.2007 13:00
Часовой пояс GMT +3, время: 07:55.
