lcash: Enabling Terminal Services on the demo VMs
Источник: http://blogs.msdn.com/lcash/archive/...-demo-vms.aspx
============== I’ve had a few questions on terminal serving into the demo VMs. I posted a note explaining how to do this by using an external network connection. http://blogs.msdn.com/lcash/archive/...-demo-vms.aspx Now the question is related to the number of connection. We have enabled terminal service on the VM but only for Administrative mode which means you can only have 2 connections to the VM. Something we have on the list to do for the upcoming Refresh 3 is to enable full terminal services. You can enable this yourself but there is a few problems :
![]() If you want to go down this path then you can get a Windows 2008 R2 VHD from the VHD Test Drive program. http://www.microsoft.com/virtualizat...ance-test.aspx There are quite a few steps to actually get the two connected but I’ll look to provide some notes on this in the future. Here are some basic notes.
Cheers Lachlan Original post at http://blogs.msdn.com/lcash Источник: http://blogs.msdn.com/lcash/archive/...-demo-vms.aspx
