Business Connector question
I'd like to update an existing customer record in the CustTable. How do I select the existing record to update. For example, I want to update the phone number. Sample of code would be helpfull. Thank you!
Read AxDvgCOMUs.chm
IAxaptaRecord::Update HRESULT Update(void); Updates the Microsoft Axapta record; that is the record is transferred to the database. Return Value The return value obtained from the returned HRESULT is one of the following: Return value Meaning S_OK Success E_FAIL General failure AXAPTA_E_NO_SECURITY_KEY The security key for updating records through the Axapta Business Connector is disabled AXAPTA_E_RECORD_NOT_VALID Microsoft Axapta record is not valid. The IAxapta object has properly logged off (IAxapta::Logoff) Comments This method resembles calling the update member method of a record in the Microsoft Axapta X++ language. Example (Visual Basic) Dim Axapta As Object Dim MyRecord As Object Set Axapta = CreateObject("AxaptaCOMConnector.Axapta") Axapta.Logon ‘ create an Axapta record Set MyRecord = Axapta.CreateRecord("MyTable") ‘ select a record MyRecord.ExecuteStmt "select * from %1 where %1.Name == ‘MyName’" ‘ set fields of record MyRecord.Field("Name") = "MyNewName" MyRecord.Field("Address") = "MyNewAddress" ‘ update the record MyRecord.Update |
object com "dundas mailer''
hi,
I use sysmailer class to send mail with Exchange 5.5 (without authentification), everything works perfectly. yesterday, my network admin modifies an exchange parameter which consists in being authenticated to use exchange, since I do not manage more to send the mail from axapta. I tried to bring a user and a password to the level of the of screen email parameter, but apparement Axapta is unaware of these parameters, anyone has this problem before? how Axapta pass parameters user and password to Exchange? -question is in axapta the Email parameters (account and password name) what is the use of? thanks for your helps. yannick. |
