Dynamics AX Geek: Finding files with WinAPI
Источник: http://AxGeek.spaces.live.com/Blog/c...DB13!150.entry
============== Axapta’s WinAPI class has a bunch of static methods to handle files. The code example below shows how to utilize some of these methods to find files. The two methods used to fetch all files matching the search criteria are findFirstFile() and findNextFile(). Don’t forget to clean up after yourself with findClose(). The code also uses three different find methods:
static void FindFile(Args _args) { #File FileName fullFileName(FileName _path, FileName _fileName) { FileName pathName; FileName fileName; FileName fileExtension; ; [pathName,fileName,fileExtension] = fileNameSplit(_fileName); return _path + '\' + fileName + fileExtension; } void findFiles(FileName _path, FileName _fileName, boolean _inclSubDir = true, FileName _prefix = fullFileName(_path,_fileName)) { FileName fileName; int hdl; ; setprefix(_prefix); if (WinAPI::folderExists(_path)) { [hdl,fileName] = WinApi::findFirstFile(fullFileName(_path,_fileName)); while (fileName) { if (WinAPI::fileExists(fullFileName(_path,fileName))) info(fileName); fileName = WinApi::findNextFile(hdl); } WinApi::findClose(hdl); if (_inclSubDir) { [hdl, fileName] = WinAPI::findFirstFile(_path+'\'+#AllFiles); while (fileName) { if (strlwr(fileName) != strlwr(_fileName) && strlwr(fileName) != strlwr('.') && strlwr(fileName) != strlwr('..') && WinAPI::pathExists(fullFileName(_path,fileName))) findFiles(fullFileName(_path,fileName), _fileName, _inclSubDir, fileName); fileName = WinApi::findNextFile(hdl); } WinApi::findClose(hdl); } } } findFiles('c:\Program Files','*.doc'); } ![]() ![]() ============== Источник: http://AxGeek.spaces.live.com/Blog/c...DB13!150.entry |
