Старый 23.11.2006, 16:00   #1
25,640 / 848 (80) +++++++
Axapta Lessons: Menu Item Properties.
Источник: http://axapta-lessons-learned.blogsp...roperties.html
Each menu item has a number of properties, which we can find in the property sheet. The next table gives an explanation of the available properties. Not all of the properties require a value.
Name: Name of the menu item in the AOT.
Label: Enter the name displayed in menus and on buttons.
HelpText: Create a help string for the menu item.
The help string is displayed below in the status bar.
Class: Choose one of the object types that match your object. Types are:
Class
Form
Job
Query
Report
Web
Web Form
Web Page
Web Report
Object: Choose one of the objects from the object type given by the Class property.
Parameters: Enter text as parameters to the Object.
EnumTypeParameters: Choose an enumerated type as parameters to the Object.
EnumParameter: Enter the parameter for the Enum Type.
RunOn: Choose whether the menu item should be executed on the client, the server or where it is called from.
ConfigurationKey: Set which key(s) are required to enable the menu item.
CountryConfigurationKey: Idem but for country.
WebConfigurationKey: Set which key(s) are required to enable the menu item used in a Web page.
SecurityKey: Set which key(s) are required to enable the menu used in conjunction with NeededAccessLevel. Default is disabled on installation.
NeededAccessLevel: Define the minimum access required if the menu item is to appear on a menu or a button. In conjunction with SecurityKey, this property is used to set access to Axapta’s menu.
Web:
WebSecureTransaction:
WebPage:
MultiSelect: Choose to allow use of the menu item on multiple record selections in forms.
CreatedBy: A read-only property set by the system.
Gives the name of the user who created the object.
CreatedDate: A read-only property set by the system.
Gives the date when the object was created.
ChangedBy: A read-only property set by the system.
Gives the name of the user who last modified the object.
ChangedDate: A read-only property set by the system.
Gives the date when the object was last modified.
ChangedTime: A read-only property set by the system.
Gives the time when the object was last changed.
LockedBy: A read-only property set by the system.
Gives the name of the user who has currently locked the object.
Remark: The EnumTypeParameter and EnumParameter are typically used to make one form behave differently depending on the menu item that is opening or calling the form.
Axapta Lessons: Menu Properties. Blog bot DAX Blogs 0 23.11.2006 16:00
Axapta Lessons: Menus. Blog bot DAX Blogs 0 23.11.2006 16:00
Axapta Lessons: Menu Items Blog bot DAX Blogs 0 23.11.2006 16:00
Axapta Lessons: Extending the Tools menu and submenus Blog bot DAX Blogs 0 28.10.2006 18:22
Axapta Lessons: Add menu options to the Add-Ins submenu Blog bot DAX Blogs 0 28.10.2006 18:22
Часовой пояс GMT +3, время: 15:01.
