I put some code into startupMethod of the info class.
Everything works fine on 2-tier enviroment. But when working in 3-tier, this code is not executed in some case (don;t know why). Does anyone know what can cause this problem? Thanks for help in advance. |
clear the client-side object cache (delete .aoc file)
DEL "%USERPROFILE%\Local Settings\Application Data\*.aoc"
-ТСЯ или -ТЬСЯ ? |
За это сообщение автора поблагодарили: ginmur (1). |
thanks, this really solved my problems
