Старый 28.04.2008, 13:05   #1
dax-lessons: Stock Market Anlaysis(DOW JONES) using X++
Источник: http://DAX-Lessons.spaces.live.com/B...FCD1!147.entry
As a commodities trader, I've never lost my fascination for the markets. This job will download historical trading data from Yahoo Finance for any valid specified date range and issue symbol, including indexes such as the Dow Industrials Average (that's "^DJI" with Yahoo).
URL Used : http://finance.yahoo.com/q/hp?s=IBM&...&g=d&z=66&y=66
* s - ticker symbol( MSFT - Microsoft, IBM etc)
* a - start month
* b - start day
* c - start year
* d - end month
* e - end day
* f - end year
* g - resolution (e.g. 'd' is daily, 'w' is weekly, 'm' is monthly)
* y is the offset (cursor) from the start date
* z is the number of results to return starting at the cursor (66
maximum, apparently)
Here is the Job:
 static void StockMarket_Analysis(Args _args)
    System.Net.WebClient web = new System.Net.WebClient();
    TextBuffer           txtBuffer = new TextBuffer();
    str                        result;
    container            recordContainer, fieldContainer;
    str                  stockContent;
    int                  i;
    FileName       nameOfTheFile;
    str                  tmpContent;
    str urlQuery         = @"http://ichart.finance.yahoo.com/table.csv?s=MSFT&a=00&b=2&c=2007&d=04&e=8&f=2008&g=d&ignore=.csv";
    CCHTMLString         htmlString;
    CCHTMLString formHTML(Container hmtlContainer, int tmp = 0)
        CCHTMLString html;
        int h;
        str start_td_th;
        str end_td_th;
        str value;
        if (tmp == 1)
            start_td_th = @"";
            end_td_th = @'';
        else
            start_td_th = @"";
            end_td_th = @'';
        html += '';
        for (h = 1; h
dax-lessons: Create Outlook Appointment or Meeting Request using X++ Blog bot DAX Blogs 0 30.04.2008 23:07
dax-lessons: Problem when creating a dynamic form with ActiveX control & Solution :) Blog bot DAX Blogs 0 30.04.2008 16:05
dax-lessons: How to write a message to the Event Log Blog bot DAX Blogs 2 04.04.2008 10:18
Часовой пояс GMT +3, время: 03:36.
