axaptapedia: Editor scripts FormatToColumnLayout
Источник: http://www.axaptapedia.com/Editor_sc...ToColumnLayout
============== Summary: Initial creation === Purpose === Allow you to select blocks of variable declarations or assignments, and format them to column layout (as suggested by msdn x++ best practices). === Description === Take the following code: static void Example(Args _args) { IntrastatParameters intrastatParameters = IntrastatParameters::find(); SalesTable salesTable; NumberSeq numberSeq; SalesLine salesLine; SalesFormLetter salesFormLetter; ; numberSeq = NumberSeq::newGetNumFromCode(SalesParameters::numRefSalesId().NumberSequence); salesTable.SalesId = numberSeq.num(); salesTable.TransactionCode = intrastatParameters.DefaultSalePurchase; salesTable.Transport = intrastatParameters.TransportModeParm; salesTable.Port = intrastatParameters.PortParm; salesTable.CustAccount = "4015"; By selecting the block of variable declarations, then choosing Scripts -> addIns -> FormatToColumnLayout, and then the same again for the block of variable assigments will result in the following: static void Example(Args _args) { IntrastatParameters intrastatParameters = IntrastatParameters::find(); SalesTable salesTable; NumberSeq numberSeq; SalesLine salesLine; SalesFormLetter salesFormLetter; ; numberSeq = NumberSeq::newGetNumFromCode(SalesParameters::numRefSalesId().NumberSequence); salesTable.SalesId = numberSeq.num(); salesTable.TransactionCode = intrastatParameters.DefaultSalePurchase; salesTable.Transport = intrastatParameters.TransportModeParm; salesTable.Port = intrastatParameters.PortParm; salesTable.CustAccount = "4015"; === Dynamics AX versions === Has been tested on Dynamics AX 4.0 SP2 and Dynamics AX 2009 === Download === *Version 1.0 - [http://www.axaptapedia.com/Image:Pri...lumnLayout.xpo download] === Installation === After downloading and importing the above xpo the following code needs to be pasted into a new method in the EditorScripts class: // /// Editor_Scripts_FormatToColumnLayout_GregP, 2009-01-24 /// Formats selected block of variable assignments or declarations into column format /// /// Currenty open editor void addIns_FormatToColumnLayout(Editor e) { ; EditorFormat::FormatToColumnLayout(e); } === Used in === [[Editor scripts]] === See also === *MSDN x++ best practice - [http://msdn.microsoft.com/en-us/library/aa619943.aspx X++ Layout] [[Category:Development tools]] Источник: http://www.axaptapedia.com/Editor_sc...ToColumnLayout
Тема | Ответов | |||
axaptapedia: Startup Tool | 0 | |||
axcoder: PowerShell + Ax | 1 | |||
axaptapedia: Load Web Documents | 1 | |||
axcoder: AxPath is supported by axaptapedia | 0 |
