Старый 27.02.2009, 22:05   #1
Microsoft Dynamics CRM Team Blog: Creating a Birthday Contact List
Источник: http://blogs.msdn.com/crm/archive/20...tact-list.aspx
Today we welcome our guest blogger CRM MVP Darren Liu from the Crowe Horwath company.
Have you ever been asked by someone to get a list of contacts having birthdays during a certain time period from CRM? If so what have you done to perform this task? Within the application, birthdays are tracked on Contact records as a single date (including year). This causes problems when searching for birthdays in a certain time period as the birth date is evaluated including the year. To illustrate, consider the following example:
· John Dole, 10/1/1980
· Adam Smith, 9/1/1970
· Mark Francis, 10/10/1960
Within CRM, searching for date is done by range. There is no easy way to identify from the above contacts all those having birthday in October as any range you choose will include the year. Wildcard functions on date fields are not a workable solution.
There are several solutions to this problem including JavaScript to parse birthday on the onChange event, a custom report or a plug-in. The desired functionality is to be able to search by birth month, birth day, and/or birth year, allowing the user to quickly identify all birthdays in a certain time period.
In this blog, I will show you how to use a pre plug-in to parse the birthday field into day, month and year. This way, the users will able to perform searches using Advanced Find. I have chosen the plug-in approach because it will help me parse the birthday field not only when the users update the birthday on the contact form but also when updating the birthday through the CRM web service for data imports and data integration.
Implement the pre plug-in
1. Create New Attributes
Create three new attribute on the Contact entity form in CRM. After creating the new attributes, publish the Contact customization. Display Name
Schema Name
Type
Searchable
Values
Birth Month
new_birthmonth
Picklist
Yes
Jan = 1, Feb = 2, Mar = 3, Apr = 4, May = 5, Jun = 6, Jul = 7, Aug = 8, Sept = 9, Oct = 10, Nov = 11, Dec = 12
Birth Day
new_birthday
Int
Yes
Min Value = 1
Max Value = 31
Birth Year
new_birthyear
Int
Yes
Min Value = 1900
Max Value = 9999
2. Create pre plug-in using Visual Studio
Create a plug-in project name Crm.Plugin, copy and paste the following code to your Plug-in project.
using System; using System.Collections.Generic; using System.Text; using Microsoft.Crm.Sdk; using Microsoft.Crm.SdkTypeProxy;   namespace Crm.Plugin { public class MonthDayYearContactPlugin : IPlugin { public void Execute(IPluginExecutionContext context) { DynamicEntity entity = null;   if (context.InputParameters.Properties.Contains(ParameterName.Target) && context.InputParameters.Properties[ParameterName.Target] is DynamicEntity) { entity = (DynamicEntity)context.InputParameters[ParameterName.Target]; if (entity.Name != EntityName.contact.ToString()) { return; } } else { return; }   try { if (entity.Properties.Contains("birthdate")) { CrmDateTime _birthdate = (CrmDateTime)entity["birthdate"]; if (_birthdate.IsNull) { entity["new_birthday"] = CrmNumber.Null; entity["new_birthmonth"] = Picklist.Null; entity["new_birthyear"] = CrmNumber.Null; } else { DateTime birthdayValue = _birthdate.UserTime; entity["new_birthday"] = new CrmNumber(birthdayValue.Day); entity["new_birthmonth"] = new Picklist(birthdayValue.Month); entity["new_birthyear"] = new CrmNumber(birthdayValue.Year); } } } catch (Exception ex) { throw new InvalidPluginExecutionException("An error occurred in the Month, Day, Year Plug-in for Contact.", ex); } } } }
3. Register the plug-in The last step is to register the plug-in. To register the plug-in, you may use the Plug-in Registration tool from the MSDN Code Gallery. After the assembly is uploaded, you need to associate the following steps to the plug-in:
Message: Create
Primary Entity: contact
Filtering Attributes: birthdate
Eventing Pipeline Stage of Execution: Pre Stage
Execution Mode: Synchronous
Triggering Pipeline: Parent Pipeline
Message: Update
Filtering Attribute: birthdate
Message: Create
Triggering Pipeline: Child Pipeline
Message: Update
Summary
That’s all there is to it! The users will now be able to use Advanced Find to quickly identify their contacts birthday in a certain time period from now on. For the existing contacts previously stored in CRM, you will need to write a one-time SQL script to update the birthday fields in the MSCRM database in order for CRM to return the correct data back to the users. Hopefully this will help you on your next CRM project.
Cheers,
Darren Liu
Старый 02.03.2009, 09:40   #2
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Я бы отчет сделал и не парился...
Microsoft Dynamics CRM Team Blog: List Web Part for Microsoft Dynamics CRM 4.0: Understanding Connections Blog bot Dynamics CRM: Blogs 0 20.01.2009 02:07
Часовой пояс GMT +3, время: 15:09.
