axaptapedia: Sandcastle
Источник: http://www.axaptapedia.com/Sandcastle
============== Summary: /* Modifying the generated reflection file (reflection.org) */ <div>== Introduction == [http://sandcastle.codeplex.com Sandcastle] documentation compilers enable managed class library developers throughout the world to easily create accurate, informative documentation with a common look and feel. With Dynamics AX, one can create [http://msdn.microsoft.com/en-us/library/cc593549.aspx XML documentation files] that can be compiled with [http://sandcastle.codeplex.com Sandcastle] to create [http://en.wikipedia.org/wiki/Microso...iled_HTML_Help CHM help] files. An [[media:ShellExecute.chm.zip|example]] of Dynamics AX XML documentation compiled with Sandcastle: [[Image:ShellExecute.png]] == Required Software == Microsoft .NET Framework Version 2.0, available [http://msdn.microsoft.com/netframewo...s/default.aspx here] HTML Help Workshop available [http://msdn.microsoft.com/library/de...pDownloads.asp here] Sandcastle available [http://sandcastle.codeplex.com/Relea...tReleases.aspx here] or [http://www.microsoft.com/downloads/d...5-696e3a4873b2 here] == Steps == # Creating the XML documentation files # Modifying the generated reflection file (reflection.org) # Optional additions # Compiling Sandcastle === Creating the XML documentation files === Follow the steps described in the [http://msdn.microsoft.com/en-us/library/cc654944.aspx Dynamics AX 2009 SDK] to generate the XML documentation files. Be sure to store both the documentation and reflection file in the same folder and name them as follows: comments.xml (documentation file) reflection.org (reflection file) === Modifying the generated reflection file (reflection.org) === In order for Sandcastle to create the table of contents and generate the html files, the following changes need to be made to the reflection file: Replace the first occurance of ''
Тема | Ответов | |||
axaptapedia: Sandcastle | 0 | |||
axcoder: PowerShell + Ax | 1 | |||
axcoder: AxPath is supported by axaptapedia | 0 |
