DeniZone: Deleting duplicate records in SQL
Источник: http://denizone.blogspot.com/2009/11...ds-in-sql.html
============== Recently I needed to delete some duplicate records across several companies in AX. The table is self-contained so I needn't worry about delete actions or validation and as there are several companies I wanted to try and do it SQL-style. So this is what I came up with DELETE FROM [Table with Duplicates] WHERE [Primary Key Field] IN DELETE FROM [Table with Duplicates] WHERE [Primary Key Field] IN ( SELECT a.[Primary Key Field] FROM [Table with Duplicates] a, [Table with Duplicates] b WHERE a.[Primary Key Field]!= b.[Primary Key Field] -- i.e. Userkey AND a.[Value to check]= b.[Value to Check] -- i.e. Lastname AND a.[Second Value to Check] = b.[Second Value to Check] -- i.e. Firstname AND a.[Primary Key Field] < b.[Primary Key Field] -- i.e. Userkey ) Respect to the original poster at SQL Server forum. Remember always to backup your data and try the SQL-statement on a test table before you do anything on data which will be used in live environments. Источник: http://denizone.blogspot.com/2009/11...ds-in-sql.html
Я надеюсь что это некий псевдо-SQL-код (не T-SQL), особенно учитывая что
-ТСЯ или -ТЬСЯ ? |
а также, то что он не смотрит ни в delete-actions, ни в ссылки на удаляемые записи
MCITP
Человек обратился на "SQL-форум", там ему подсказали ответ на извечный вопрос "как найти дубликаты" со знаком ">", человеку понравилось, решил поделиться...
![]() как-то уже обсуждалось тут: Distinct в QueryBuildDataSource
Zhirenkov Vitaly |
