Старый 20.04.2010, 20:05   #1
25,646 / 848 (80) +++++++
Rajdip's space: When using index (not using hint) in a select statement without 'GroupBy' or 'OrderBy' in what sequence do the records occur
Источник: http://rajdipdas.spaces.live.com/Blo...25FA!283.entry
When using index (not using hint) in a select statement without 'GroupBy' or'OrderBy' in what sequence do the records occurAnswer:When using Index hint, the index chosen is hinted to the SQL server as theone that should be used for the query.(you shouldn't use this unless you are very sure that's the best selectiveindex there ever will be for the table)the index (without hint) is interpreted into a simple ORDER BY clause, sothe records will be ordered in the order of the fields from the index.( you can turn on logging SQL statements and see the actual query being sentto the server)
emeadaxsupport: Error “Not enough rights” when you select Category in Electronic Time Card Blog bot DAX Blogs 0 03.04.2010 05:15
Microsoft Dynamics CRM Team Blog: Dude, Where’s My Space? Blog bot Dynamics CRM: Blogs 0 15.01.2009 23:05
Fred Shen: Always use recId to know if a select statement returns a record Blog bot DAX Blogs 0 28.10.2006 16:40
Почему не работает not exists в конструкции while select Владимир Максимов DAX: Программирование 2 03.02.2004 12:17
Часовой пояс GMT +3, время: 03:32.
