emeadaxsupport: Passing UtcDateTime values in extended query syntax
Источник: http://blogs.msdn.com/emeadaxsupport...ry-syntax.aspx
============== Recently I was looking into the issue of passing UtcDateTime values into a query in X++ using extended query syntax. First I will just clarify what I mean when saying "extended query syntax": This is extended query syntax: ('(validUntilDate = %1)', DateTimeUtil::toStr(utcRefDateTime)); This is the regular syntax for ranges: ('%1', queryValue(utcRefDateTime)); As you can see in my examples above, for the regular syntax using queryValue() is fine, but when using the extended query syntax, there are 3 basic rules for utcDateTime values: - it's necessary to use DateTimeUtil::toStr() to pass utcDateTime values. - The query string needs to have brackets around it. - No speechmarks/quotations should be used around the utcDateTime value. So working example: queryStr = strfmt(@"((StartDate < %2) && (EndDate < %2) && (validUntilDate = %1))", DateTimeUtil::toStr(2010-01-10T14:00:00), DateTimeUtil::toStr(2010-01-10T17:00:00)); And a failing example with brackets missing: queryStr = strfmt(@"((StartDate < %2) && EndDate < %2 && (validUntilDate = %1))", DateTimeUtil::toStr(2010-01-10T14:00:00), DateTimeUtil::toStr(2010-01-10T17:00:00)); Failing with speechmarks/quotations: queryStr = strfmt(@"((StartDate < %2) && (EndDate < '%2') && (validUntilDate = %1))", DateTimeUtil::toStr(2010-01-10T14:00:00), DateTimeUtil::toStr(2010-01-10T17:00:00)); There is an exception to these rules, that is when using 1900-01-01T00:00:00. Most functions in X++ are returning this as NULL when converting to a string but for the extended range syntax to work correctly we need it to be returned as a string, so the following functions cannot be used: QueryValue() dateTime2Str() DateTimeUtil::toStr() Global::utcDateTimeNull() DateTimeUtil::minValue() So in my environment I have introduced a new global function to make it easier for me to convert utcDateTime values to strings for extended query ranges, called dateTime2strQuery() static str dateTime2strQuery(utcDateTime _utcDateTime) { str cvtDateTime; ; If(_utcDateTime==DateTimeUtil::minValue()) cvtDateTime = '1900-01-01T00:00:00'; else cvtDateTime = DateTimeUtil::toStr(_utcDateTime); return cvtDateTime; } So now my working example looks like this: queryStr = strfmt(@"((StartDate < %2) && (EndDate < %2) && (validUntilDate = %1))", dateTime2strQuery(2010-01-10T14:00:00), dateTime2strQuery(2010-01-10T17:00:00)); Источник: http://blogs.msdn.com/emeadaxsupport...ry-syntax.aspx
За это сообщение автора поблагодарили: samolalex (1). |
Теги |
extended query, extended query syntax, utcdatetime |
