01.07.2010, 22:07 | #1 |
Kashperuk Ivan: Tutorial: Brief description of ways to close a form in AX
Источник: http://kashperuk.blogspot.com/2010/0...f-ways-to.html
============== We had this question asked on one of the internal AX forums, and Michael Fruergaard wrote a short description of each method you can use. Re-posting it here with some extra comments, so that new developers can read and understand, when to use what method. There are “only” 5 ways to close a form:
02.07.2010, 14:30 | #2 |
Алексей задал вопрос в комментариях, приведу ответ и здесь для общественности
Hi,
What about infolog.close() method? Regards, Alex Цитата:
Infolog.close() is a special method, called from the kernel (through infolog.formNotify()), when super() is called inside the close() method.
It does not actually do anything visible, simply updates some global variables for lastActiveForm and document handling. |
За это сообщение автора поблагодарили: alex55 (1). |
