Старый 15.04.2011, 00:12   #1
sumitsaxfactor: Listing out Published SQL Servers in AX
Источник: http://sumitsaxfactor.wordpress.com/...servers-in-ax/
Recently, I had a requirement where I had to populate list of SQL Servers in a table in AX and all this had to be done from within AX.
I couldn’t find any support directly in AX, so I decided to use .Net classes for this purpose.
Here is a job that can help you achieve the same.
static void getListOfSQLServers(Args _args)
    System.Data.Sql.SqlDataSourceEnumerator dataEnum;
    System.Data.DataTable                   dataTable;
    System.Data.DataRowCollection           collection;
    System.Data.DataRow                     row;
    System.Object                           serverObj, instanceObj;
    int sqlCount, i;
    str   serverName, instanceName;
    dataEnum = System.Data.Sql.SqlDataSourceEnumerator::get_Instance();
    dataTable = dataEnum.GetDataSources();
    collection = dataTable.get_Rows();
    sqlCount = collection.get_Count();
    for (i = 0; i < sqlCount; i++)
        row = collection.get_Item(i);
        serverObj = row.get_Item("ServerName");
        instanceObj = row.get_Item("InstanceName");
        serverName = serverObj.ToString();
        instanceName = instanceObj.ToString();
        if (instanceName)
            info(strfmt("%1\\%2", serverName, instanceName));
        else
            info(serverName);
Dynamics AX: Dynamics AX 2009 & SQL Server 2008 Blog bot DAX Blogs 0 10.06.2008 21:08
Часовой пояс GMT +3, время: 11:19.
