dax-lessons: Get underlying SQL query using getSQLStatement [Dynamics AX 2012]
Источник: http://dynamicsaxgyan.wordpress.com/...amics-ax-2012/
============== Friends, To get the underlying SQL query or statement from the X++ query, use getSQLStatement method. getSQLStatement is a new method that has been introduced in tables in AX 2012. The X++ select has been extended with the generateonly command that instructs the underlying data access framework to generate the SQL query without actually executing [...] ![]() Источник: http://dynamicsaxgyan.wordpress.com/...amics-ax-2012/
За это сообщение автора поблагодарили: Logger (1), Ace of Database (2). |
Теги |
generateonly, getsqlstatement |
