emeadaxsupport: AX2012 Retail error 32769 in Store connect while running P-job
Источник: http://blogs.msdn.com/b/axsupport/ar...ing-p-job.aspx
============== Version: AX 2012 FPK Symptom: When running the P job following error message appears in the event log or in the Retail store connect database outgoingmessages table. Error 32769 2012.6.7 13:21:45:114 (4684) [1] CCommMgr::HandleException: Target request handler failed to process target request header: Microsoft.Dynamics.Retail.StoreConnect.Request.SQLHandler.SCSqlRequestHandlerException: SQL target request handler failed to process request: SQL operation failure. ---> System.Data.SqlClient.SqlException: Invalid column name 'dataAreaId'. Invalid column name 'replicationCounterFromOrigin'. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning() at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at Microsoft.Dynamics.Retail.StoreConnect.Request.SQLHandler.SCSqlWriteRequestRunner.Run(SqlConnection connection, SqlTransaction transaction) at Microsoft.Dynamics.Retail.StoreConnect.Request.SQLHandler.SCSqlTargetRequestHandler.ProcessWriteRequest(SqlConnection connection, SqlTransaction transaction) at Microsoft.Dynamics.Retail.StoreConnect.Request.SQLHandler.SCSqlTargetRequestHandler.ProcessTargetRequestHeader(ISCTargetRequestHeader targetRequestHeader) --- End of inner exception stack trace --- at Microsoft.Dynamics.Retail.StoreConnect.Request.SQLHandler.SCSqlTargetRequestHandler.ProcessTargetRequestHeader(ISCTargetRequestHeader targetRequestHeader) at CCommMgr.ProcessTargetRequest(CCommMgr* , basic_string* r_file_path, SCRequestHandlerManager scRequestHandlerManager) Reason: The main reason is a code problem in AX that generates a wrong WHERE criteria when figuring out the connection-string for the AX database because of which it picks the first connection-profile mapped to the Store Connect profile mapped to the AOS profile. If the database profile happens to be mapped first, then the connection-string for the Store database is used as if it was the AX database causing the "REPLICATIONCOUNTERFROMORIGIN" field missing error. SELECT * FROM [RETAILCONNCONNECTIONPROFILE] Incorrect setup, were the database profile was created before the AOS profile Correct setup: ![]() Workaround: 1. The normal setup is to have two store connects installed.
2. Second workaround, Delete all profiles Create the profiles again. Map the AOS profile to the Store Connect profile first. Map the Database profile to the Store Connect profile next. This issue will be fixed in the next major release, expected 6.2 Author: Kim Truelsen Date: 10/6-2012 Источник: http://blogs.msdn.com/b/axsupport/ar...ing-p-job.aspx
