Старый 08.11.2012, 11:11   #1
Malaysia: Using a tree control
Источник: http://axmas.blogspot.com/2012/11/us...e-control.html
1. In the AOT, create a new class named BudgetModelTree with the following code:
class BudgetModelTree
FormTreeControl tree;
BudgetModelId modelId;
public void new(FormTreeControl _formTreeControl, BudgetModelId _budgetModelId)
tree = _formTreeControl;
modelId = _budgetModelId;
public static BudgetModelTree construct(FormTreeControl _formTreeControl, BudgetModelId_budgetModelId = '')
return new BudgetModelTree(_formTreeControl, _budgetModelId);
private TreeItemIdx createNode(TreeItemIdx _parentIdx, BudgetModelId _modelId, RecId _recId)
TreeItemIdx itemIdx;
BudgetModel model;
BudgetModel submodel;
model = BudgetModel::find(HeadingSub::Heading, _modelId);
itemIdx = SysFormTreeControl::addTreeItem(tree, _modelId + ' : ' + model.Txt, _parentIdx, _recId, 0,true);
if (modelId == _modelId)
tree.select(itemIdx);
while select submodel
where submodel.ModelId == _modelId && submodel.Type == HeadingSub::SubModel
this.createNode(itemIdx, submodel.SubModelId, submodel.RecId);
return itemIdx;
public void buildTree()
BudgetModel model;
tree.deleteAll();
tree.lock();
while select RecId, ModelId from model
where model.Type == HeadingSub::Heading
notExists join submodel
where submodel.SubModelId == model.ModelId &&
itemIdx = this.createNode(FormTreeAdd::Root, model.ModelId, model.RecId);
SysFormTreeControl::expandTree(tree, itemIdx);
tree.unLock(true);
2. In the AOT, open the BudgetModel form's design, expand the Body group, then
expand the GridContainer group, and change the following property of the
BudgetModel grid control:
Property Value
Visible No
3. Create a new Tree control right below the BudgetModel grid with the
following properties:
Property Value
Name Tree
Width Column width
Height Column height
Border Single line
RowSelect Yes
4. Add the following code to the bottom of the form's class declaration:
BudgetModelTree modelTree;
5. Add the following code to the bottom of form's init():
modelTree = BudgetModelTree::construct(Tree);
modelTree.buildTree();
6. Override selectionChanged() on the Tree control with the following code:
public void selectionChanged(FormTreeItem _oldItem, FormTreeItem _newItem, FormTreeSelect _how)
BudgetModel model;
super(_oldItem, _newItem, _how);
if (_newItem.data())
select firstOnly model
where model.RecId == _newItem.data();
if (model.Type == HeadingSub::SubModel)
modelId = model.SubModelId;
where model.ModelId == modelId && model.Type == HeadingSub::Heading;
BudgetModel_ds.findRecord(model);
BudgetModel_ds.refresh();
7. Override the delete() method on the BudgetModel data source with the
following code:
public void delete()
super();
if (BudgetModel.RecId)
8. Override the delete() method on the SubModel data source with the
following code:
super();
if (SubModel.RecId)
9. Add the following code to the bottom of the write() method on the BudgetModel
data source:
10. Override the write() method on the SubModel data source and add the following
code to its bottom:
11. In the AOT, the BudgetModel form should look like the following screenshot:
12. To test the tree control, open Budgeting | Setup | Budget models. Notice how the
ledger budget models are presented as a hierarchy:
ax_gfm_framework_team: Integrating a Source Document with Budget Control Blog bot DAX Blogs 0 18.07.2012 00:11
axinthefield: Journals - Balance Control Accounts Blog bot DAX Blogs 0 21.06.2011 12:11
emeadaxsupport: Renaming an AOT object in Dynamics AX 2009 that is under source control with Team Foundation Server Blog bot DAX Blogs 0 06.10.2009 02:05
mscrm4ever: Creating a Network Path Text Control Blog bot Dynamics CRM: Blogs 0 21.03.2009 06:43
Malaysia: Set Control and Keyborad Enter Blog bot DAX Blogs 0 15.08.2007 13:00
Часовой пояс GMT +3, время: 04:23.
