ax-erp: Convert from Time Zone Before Persisting in X++
Источник: http://microsoft-dynamics-ax-erp.blo...ne-before.html
============== In X++ code, SQL statements that read and write DateTime fields from tables do not implicitly perform time zone conversions. Explicit calls to methods on the DateTimeUtil class can be added to convert a database DateTime column or an X++ utcdatetime value to a particular time zone. ![]() DateTime Values Must be Stored as UTC Any X++ code that you write needs to store DateTime values in UTC. Your code should convert any non-UTC date/time values into UTC before storage. ![]() Reading DateTime Values in UTC Each time you write an X++ method that reads date/time values from the database, you need to understand whether the date/times should be converted from UTC, and if so into which time zone. X++ Example of Inserting DateTime This section contains:
The following X++ code example demonstrates the use of certain date/time related types and methods. DateTimeUtil class
static void DateTimeInsertJob( Args _args ) { MeetingTable meetingXRec; // Inherits from xRecord class. date date2; timeOfDay time3; utcdatetime utcDt5 ,utcDt6; str sMeetingDate , sMeetingTime , sMeetingDateTimeUtc , sMeetingDateTimeLocalTz , sMeetingId; ; // Empty the MeetingTable table of all rows. delete_from meetingXRec; // Prepare a date and a timeOfDay, to use // in building a utcdatetime. date2 = 27\11\2006; time3 = str2time( "06:44:55" ); //--------------------------------- // Combine a literal date and timeOfDay, into a // utcdatetime variable, without conversion from UTC. utcDt5 = DateTimeUtil ::newDateTime ( date2 , time3 // Omitting the optional Timezone parameter, // letting it default to UTC. ); // Insert a row. meetingXRec = null; meetingXRec .MeetingId = 1; meetingXRec .MeetingDate = date2; meetingXRec .MeetingTime = time3; meetingXRec .MeetingDateTime = utcDt5; meetingXRec .insert(); print( "[11], MeetingId == 1, UTC, utcDt5 == " + DateTimeUtil ::toStr( utcDt5 ) ); //--------------------------------- // Use a hard-coded Timezone enum value to convert // a utcdatetime value for a particular time zone. utcDt5 = DateTimeUtil ::newDateTime ( date2 , time3 // A hard-coded Timezone value. , Timezone ::GMTMINUS0500EASTERNTIME ); // Insert a row. meetingXRec = null; meetingXRec .MeetingId = 2; meetingXRec .MeetingDate = date2; meetingXRec .MeetingTime = time3; meetingXRec .MeetingDateTime = utcDt5; meetingXRec .insert(); print( "[21], MeetingId == 2, UTC-0500, utcDt5 == " + DateTimeUtil ::toStr( utcDt5 ) ); //--------------------------------- // Convert to a hard-coded time zone by using // ::applyTimeZoneOffset, instead of a time zone // parameter in ::newDateTime. Same outcome. utcDt5 = DateTimeUtil ::newDateTime ( date2 , time3 // Omitting the optional Timezone parameter, // letting it default to UTC. ); utcDt5 = DateTimeUtil ::applyTimeZoneOffset ( utcDt5 // A hard-coded Timezone value. , Timezone ::GMTMINUS0500EASTERNTIME ); // Insert a row. meetingXRec = null; meetingXRec .MeetingId = 3; meetingXRec .MeetingDate = date2; meetingXRec .MeetingTime = time3; meetingXRec .MeetingDateTime = utcDt5; meetingXRec .insert(); print( "[31], MeetingId == 3, UTC-0500, utcDt5 == " + DateTimeUtil ::toStr( utcDt5 ) ); //--------------------------------- // Use the user's preferred time zone to convert // a utcdatetime value. utcDt5 = DateTimeUtil ::newDateTime ( date2 , time3 // User's preferred time zone. , DateTimeUtil ::getUserPreferredTimeZone() ); // Insert a row. meetingXRec = null; meetingXRec .MeetingId = 4; meetingXRec .MeetingDate = date2; meetingXRec .MeetingTime = time3; meetingXRec .MeetingDateTime = utcDt5; meetingXRec .insert(); print( "[41], MeetingId == 4, User TZ, utcDt5 == " + DateTimeUtil ::toStr( utcDt5 ) ); pause; /********************** This code produces the following output. MeetingId == 4 shows the test run occurred when the user's preferred time zone was UTC-0500 (Eastern Time). [11], MeetingId == 1, UTC, utcDt5 == 2006-11-27T06:44:55 [21], MeetingId == 2, UTC-0500, utcDt5 == 2006-11-27T11:44:55 [31], MeetingId == 3, UTC-0500, utcDt5 == 2006-11-27T11:44:55 [41], MeetingId == 4, User TZ, utcDt5 == 2006-11-27T11:44:55 **********************/ } Источник: http://microsoft-dynamics-ax-erp.blo...ne-before.html
