21.03.2013, 13:35 | #1 |
Ax 2012 filter by Dimension table
Hi,
I created new table, which is used as financial dimension. So far it works ok. It is possible to filter transactions by certain dimension code. But the question is, how to filter by other fields from that dimension table? Not just by dimension code, but an example, by description of code. Br, Maris |
22.03.2013, 09:44 | #2 |
Press Ctrl+F3 and add linked DataSource. Or add linked DataSource previously when designing a form.
22.03.2013, 17:26 | #3 |
Use DimensionAttributeLevelValueView + dimensionProvider class
http://sumitsaxfactor.wordpress.com/...anges-ax-2012/ |
За это сообщение автора поблагодарили: S.Kuskov (2). |
