emeadaxsupport: Customer Free Text Invoice form the delete button is disabled.
Источник: http://blogs.msdn.com/b/axsupport/ar...-disabled.aspx
============== Issue: The disable button on the Customer Free Text Invoice is disabled for a user which has the CustFreeInvoiceMaintain privilege assigned. Summary: This situation only occurs in Ax2012 as Ax2012R2 has made a change to the CustFreeInvoiceListPage entry point within the CustFreeInvoiceMaintain privilege of setting the Access Level to delete from read. Workaround: In Ax2012 open a developer workspace - Open the AOT - Navigate to Security - Privileges - CustFreeInvoiceMaintain - Expand CustFreeInvoiceMaintain, select Entry Points - CustFreeInvoiceListPage In the properties change the Access Level from Read to Delete Источник: http://blogs.msdn.com/b/axsupport/ar...-disabled.aspx
