Старый 27.05.2013, 11:11   #1
Anitha Roy is offline
Anitha Roy
Grid Refreshing by same value in string field of all records if i'm modifying the one record of that string field...
Hello friends,
Hope you ppl are doing well.
i'm stuck with a problem plz help me out...
For Example:
I'm passing the values from Base form of cust Account(Unbound control) and their addresses into a grid to child form.But i have to able to edit the grid fields also after passiing the values..but when i'm modifying the a field of one record it is changing the value for all records in the grid...
Plz let me know if you solution for this...
Старый 27.05.2013, 14:32   #2
S.Kuskov is offline
S.Kuskov
3,440 / 1775 (66) ++++++++
Show screenshot with property window of modified control
Старый 27.05.2013, 16:02   #3
Anitha Roy
hi.
I'm in AX 2012 R2
Старый 27.05.2013, 15:29   #4
pitersky is offline
pitersky
северный Будда
Аватар для pitersky
1,510 / 435 (18) +++++++
What is the number of version you work with? DAX2012 have a lot of differences from DAX2009 in AR forms
Вячеслав
Последний раз редактировалось pitersky; 27.05.2013 в 15:31.
Kashperuk Ivan: Tool: Updating a field value for all selected records on a form Blog bot DAX Blogs 2 09.10.2011 20:18
emeadaxsupport: Wrong data shown in the grid, if the table field is an Int 64 and the form control is an IntEdit instead of an int64edit. Blog bot DAX Blogs 3 22.07.2010 18:00
palleagermark: EP 2009: Edit a record outside a grid Blog bot DAX Blogs 0 05.11.2008 11:05
palleagermark: Saving the reference to a unique record as a string Blog bot DAX Blogs 0 20.10.2008 11:05
referencing grid columns, finding selected records Sveta1978 DAX in English 4 15.12.2007 15:19
Часовой пояс GMT +3, время: 22:07.
