axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework standalone version for AX 2012 R2 without installing full CU7
Источник: http://blogs.msdn.com/b/axsa/archive...-full-cu7.aspx
============== We have recently released the new version for Microsoft Dynamics AX 2012 Data Import/Export Framework as part of Microsoft Dynamics AX 2012 R2 CU7. We received lot of requests to get the new version for AX 2012 R2 (Base R2 and/or CU1, CU6, hotfixes) without taking full CU7. To make this happen, we have released an application hotfix for DIXF which can be installed on AX 2012 R2 (Base R2 and/or CU1, CU6, hotfixes). The hotfix does not contain the binary files for the Data Import/Export Framework. You must install the binary files for the Data Import/Export Framework by using the CU7 update installer. Application Components The application hotfix contains the application files for the version of the Data Import/Export Framework that was released with cumulative update 7. Important: This hotfix does not contain the binary files for the Data Import/Export Framework. You must install the binary files for the Data Import/Export Framework by using the CU7 update installer. Download: Application files for the Data Import/Export Framework, cumulative update 7 version Instructions: To install the Data Import/Export Framework:
Binary Components You must install the binary files for the Data Import/Export Framework by using the CU7 update installer. Download: Microsoft Dynamics AX 2012 R2 Cumulative Update 7 (KB2885603 ) Instructions: Install Data import export framework Client, AOS and Service components. http://technet.microsoft.com/EN-US/l...x%23InstallCU7 CU 7: Install the Data Import/Export Framework (binary) As of cumulative update 7, you can install the Data Import/Export Framework from the update installer. For an overview of the Data Import/Export Framework, see Data import/export framework user guide ( (DIXF, DMF). Caution If you have previously installed the Data Import/Export Framework from InformationSource, you must fully uninstall it before installing again with cumulative update 7 for Microsoft Dynamics AX 2012 R2. This includes removing all binary files by using Add/Remove Programs, and the uninstalling Data Import/Export Framework model. For more information see How to: Remove (Uninstall) a Model.
If you are installing on the AOS computer, specify the name of the server that is running SQL Server Integration Services.
