Старый 01.08.2014, 17:11   #1
palleagermark: Use the Filter tab of the Find dialog
Источник: http://www.agermark.com/2014/08/use-...nd-dialog.html
I have started to read Inside Dynamics AX 2012 R3 and I read it from cover to cover. Sometimes you get reminded of great but forgotten features when doing so.
This time I was reminded of the Filter tab of the Find dialog. With this filter you can created any kind of boolean function to control what the tool returns of findings.
Here is a small example you can use to find methods with more that 50 lines:
Here I have used it on the SalesFormLetter class.
atinkerersnotebook: Use Filter By Selection To Quickly Find Common Records Blog bot DAX Blogs 0 12.03.2014 14:11
palleagermark: "Find as you type" in the AX 2012 X++ editor Blog bot DAX Blogs 0 02.02.2012 15:11
Microsoft Dynamics CRM Team Blog: Welcome to the World of Dialogs - Part 1 Blog bot Dynamics CRM: Blogs 0 02.02.2011 21:11
palleagermark: Dialog error when adding batch tasks to a batch job Blog bot DAX Blogs 0 10.06.2009 20:05
Kashperuk Ivan: Hotkeys and Find vs Filter in Dynamics AX 2009 Blog bot DAX Blogs 2 11.03.2008 12:06
Часовой пояс GMT +3, время: 08:10.
