emeadaxsupport: How to assign an LTL Freight class code to an item using Nation Motor Freight Classification (NMFC) codes
Источник: http://blogs.msdn.com/b/axsupport/ar...mfc-codes.aspx
============== This blog posts assumes a working knowledge of the Transportation management (TMS) module in Microsoft Dynamics AX 2012 R3 In Transportation management module of AX 2012 R3 there exist freight engines. These engines are used to calculate costs for freight loads. Some of the engines make use of LTL Freight class codes in their calculation. In this blog you will learn how to associate an LTL code with an NMFC code and associate an NMFC code to an item. The end result will be an automatic association of an item to an LTL code. Steps 1) In the Transportation management module create your LTL class code. a. Transportation management | Setup | General LTL class ![]() b. In the LTL class form click New i. LTL class = 92.5 ii. Name = 92.5 iii. Class = 92.5 ![]() iv. Close the LTL class form 2) In the Transportation management module create an NMFC code and associate the LTL class code to it a. Transportation management | Setup | General | NMFC codes b. In the NMFC code form click new i. NMFC code = 92.5 ii. Name = Electronics iii. LTL class = 92.5 iv. BOL handling type = Unit ![]() v. Close the form 3) Finally the NMFC code must be associated to a product. It is important to note that because NMFC code associations are consistent that the relationship is setup in the “Product details” form and not the “Released product details” form. The controls to assign an NMFC code to a product in the “Released product details” form are disabled. a. Product information management | Common | Products | Products i. Select any product and click Product | Maintain | Edit on the panel ![]() ii. In the Product details from on the Warehouse management fast tab set the NMFC code = 92.5 iii. Save the form ![]() iv. Now anytime that item is rated the LTL code should automatically populate. Источник: http://blogs.msdn.com/b/axsupport/ar...mfc-codes.aspx
