emeadaxsupport: How to install and set up integration with MS Project in AX 2012 R3 successfully the first time
Источник: http://blogs.msdn.com/b/axsupport/ar...irst-time.aspx
============== Before you begin Integration with MS Project is done as an Office add-in for Dynamics AX 2012. When you install Office add-ins for Dynamics AX 2012 it will only install the add-ins for the Office products that are installed on the client. If you did not have MS Project installed the first time you installed the AX Office add-ins, then you have to uninstall the Office add-ins using the AX 2012 setup. Then install MS Project and reinstall the Office add-ins using AX 2012 setup. Important There is released a binary/kernel hotfix (KB 3000048) for Dynamics AX 2012 R3 that fixes a problem with date format causing the sync to fail if you use other regional settings/date format than US format (selecting non US format in Control panel/Region). The hotfix (KB 3000048) can be downloaded from LCS: https://fix.lcs.dynamics.com/Issue/R...ce1e83ead57375 The AX kernel version for KB 3000048 is 6.3.164.3179 so if you are running with a kernel with higher build number, then you already have the fix. Note: When you install the AX Office add-ins then be sure that the KB 3000048 kernel or kernel hotfix with higher build number is slipstreamed with the AX Setup files. https://technet.microsoft.com/en-us/.../hh378076.aspx Installation When you are ready to install, then this is a god guide to follow when installing MS Project integration: http://blogs.msdn.com/b/axsa/archive...x-2012-r3.aspx Setup after installation Check that the services for project integration, AifProject and AifProjWBS, is deployed and Activated. System administration > Services and Application Integration Framework > Inbound ports ![]() If not activated, then Activate them by select the port and click Activate button. If not deployed, then open AOT (developer workspace) in AX client. Go to AOT > Service Groups > AifProject > right click and Deploy Service. Go to AOT > Service Groups > AifProjWBS > right click and Deploy Service. ![]() AX client configuration The MS Project integration is designed to use the default client and Business Connector configuration and there is no option to specify a configuration file, so you can only connect to one AOS/AX system at the time. If you need to connect to another AX environment (e.g. if you have a prod and test system), then you need to open AX client configuration utility (from Administrative tools). For both configuration targets – AX client and Business connector: Select the configuration for the other AX system and click Apply. Note: You can have only one AX client and one MS Project instance open at the same time. Set up parameters for Microsoft Project integration Go to Project management and accounting > Setup > Project management and accounting parameters > General Specify where to save the project files. If you select “Local or network folder”: Do not use _ (underscore) in the folder path/name. Example: Do not use \\server\Project_Files - use \\server\Project Files or \\server\ProjectFiles Use a network folder (UNC path) in multi user environment. Local is only for single machine test environment. ![]() It is also possible to select to store the project files in SharePoint Collaboration workspace. You can store Microsoft Project files in Microsoft SharePoint only if the associated collaboration workspace is using a project site template or team site template. You can change those settings in the Collaboration workspace settings form. Be sure that all project users have access to the folder/workspace where the project files are stored. Project categories In order to be able to select Project categories in MS Project then the Project Category (Project management and accounting > Setup > Categories > Project categories) must be set up as Transaction type = Hour and Active in journals = enabled. ![]() All Project categories specified on WBS lines must have this setup. Some links to documentation and info: TechNet doc: https://technet.microsoft.com/en-us/.../dn528663.aspx Project Management whitepapers: http://blogs.msdn.com/b/axsupport/ar...t-project.aspx Project Management demo on YouTube: https://www.youtube.com/watch?v=XZrI...ature=youtu.be Источник: http://blogs.msdn.com/b/axsupport/ar...irst-time.aspx
