Старый 22.07.2016, 22:13   #1
organicax: Field ‘Contact Id’ must be filled in when assigning a campaign to a source code
Источник: https://organicax.com/2016/07/22/fie...a-source-code/
When you are setting up a catalog for a call center and you are going to use source codes. A source code can be associated with a campaign. If you get an error when trying to do this something to the effect “field ‘Contact Id’ must be filled in” then you need to make sure you have a contact for the customer.
Here is a quick overview.
AX2012 R3 CU10.
Cheers
Lachlan
Filed under: Retail, Sales and marketing
organicax: Assigning a WMS work template to a disposition code Blog bot DAX Blogs 0 10.05.2016 10:11
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
wiki.dynamicsbook: Changes Made in Navision Attain 3.60 Blog bot Dynamics CRM: Blogs 0 02.09.2008 13:23
wiki.dynamicsbook: Changes Made in Navision Attain 3.01B Blog bot Dynamics CRM: Blogs 0 21.08.2008 20:43
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 13:40.
