dyn365finsupport: Installing the Dynamics 365 for Financials Outlook add-in on Exchange 2013
Источник: https://blogs.msdn.microsoft.com/dyn...exchange-2013/
============== If you attempt to deploy the Dynamics 365 for Financials Outlook add-in using the ‘Set up Outlook for Financials’ assisted setup option and your organization is running Exchange 2013 it will fail. You can also attempt to manually install the add-in manifest files by downloading them from the ‘Office Add-In Management’ page in Financials. After you’ve downloaded the files and then installed them by going to Outlook > File > Manage Add-ins – You may see the following error: “This app can’t be installed. The manifest file for this app is too large. It must be smaller than 32 KB.” The issue here is that the Contact Insights manifest file is too large for Exchange 2013. You can download the modified (smaller) version of this file for use with Exchange 2013 here: contactinsights_outlook2013_d365financials_template You must edit the file before installing it into your environment.
https://community.dynamics.com/business/f/758#pi53924=1 Источник: https://blogs.msdn.microsoft.com/dyn...exchange-2013/
