emeadaxsupport: Dynamics 365 Retail: Working with the New “Manage Shifts” Functionality in POS
Источник: https://blogs.msdn.microsoft.com/axs...nality-in-pos/
============== On Dynamics 365 for Finance and Operations functionality was added for managers to recover and unblock terminals. This functionality was added with KB 4101053 on 7.2 and KB 4338783 (Application Update 7.3.2.5) and the updates are available in Lifecycle Services. Prior to the hotfixes when POS had an issue closing a shift, the shift could... Read more Источник: https://blogs.msdn.microsoft.com/axs...nality-in-pos/
Сообщение от Blog bot
![]() Prior to the hotfixes when POS had an issue closing a shift, the shift could be stuck in an Open and Closed state. The shift for the terminal is in the CRT.RETAILSHIFTSTAGINGTABLE (which would be considered an open shift) and the AX.RETAILPOSBATCHTABLE (which would be considered a closed shift). When the shift for a terminal is in this state, the shift could not be closed, and a new shift could not be open.
The above example is one of the reasons the new Manage Shifts functionality was needed. |
