msdynamicsworld: How to post Fixed Bid and Time & Material-based invoices in Dynamics 365 Finance and Operations from Project Operations
Источник: https://msdynamicsworld.com/story/ho...and-operations
============== We recently examined how the contract and milestones flow between Microsoft Dynamics 365 Customer Engagement and Finance & Operations in the integrated scenario supported by Dynamics 365 Project Operations. The next step is to post the Milestones or the Approved Time entries (in case of T&M-based projects) in Dynamics 365 Finance and Operations (D365FO). Milestone-based Invoice posting Let’s looks at first Milestone-based Invoice posting in D365FO for a Fixed Bid Project. (Note: How to log in to the environment is shown in my previous blog in the link above.) Step 1: Login to the Dynamics 365 Customer Engagement (CE) Project Operations environment, navigate to the Milestone that you need to Invoice, and flip the status to “Ready for invoicing”. ![]() Step 2: The invoice is created in the CE environment and you need to confirm the same. ![]() Upon confirming the invoice, the integration pushes the invoice data to the D365FO environment. Step 3: Navigate to D365FO environment and go to Project Management and Accounting-->Import from staging table. This will import all the transactions available in the staging area to D365FO environment. ![]() ![]() ![]() Step 4: At this juncture the Invoice is now posted to the D365FO environment. To check the same in D365FO environment navigate to Project Management and Accounting Module-->Pending project transactions ![]() You can see the Invoices milestone below. ![]() Step 5: Select the invoice and click on Post. This is when the invoicing of the milestone is completed. This step is recommended to be performed by the Accounts Manager. ![]() ![]() ![]() Invoicing Time and Material projects Now we shall examine the steps required to invoice Time and Material projects. Источник: https://msdynamicsworld.com/story/ho...and-operations
