05.09.2024, 06:34 | #1 |
dynamicsnavax: Fabric - Sample Notebook scripts for MSDyn365FO
Источник: http://dynamicsnavax.blogspot.com/20...ripts-for.html
============== This will be a fairly straightforward blog post covering different ways of copying data from a shortcut delta table into a delta table created automatically via a notebook. Select statement with a join %%sql SELECT party.recid AS PartyId ,party.name AS Name ,COALESCE(party.namealias, '') AS ShortName ,COALESCE(postal.countryregionid, '') AS Country ,COALESCE(postal.state, '') AS State ,COALESCE(postal.city, '') AS City ,COALESCE(postal.street, '') AS Street ,COALESCE(postal.zipcode, '') AS PostCode ,COALESCE(phone.locator, '') AS PhoneNumber ,COALESCE(email.locator, '') AS Email FROM dirpartytable party LEFT OUTER JOIN logisticspostaladdress postal ON postal.location = party.primaryaddresslocation AND postal.validto > current_date() -- filters only valid(effective) addresses LEFT OUTER JOIN logisticselectronicaddress phone ON phone.recid = party.primarycontactphone LEFT OUTER JOIN logisticselectronicaddress email ON email.recid = party.primarycontactemail You should see a table result showing below your query. Create table if not exists This is a one of copy and will not copy data if the table exists already. %%sql CREATE TABLE IF NOT EXISTS fact_dirpartytable USING DELTA AS SELECT party.recid AS PartyId ,party.name AS Name ,COALESCE(party.namealias, '') AS ShortName ,COALESCE(postal.countryregionid, '') AS Country ,COALESCE(postal.state, '') AS State ,COALESCE(postal.city, '') AS City ,COALESCE(postal.street, '') AS Street ,COALESCE(postal.zipcode, '') AS PostCode ,COALESCE(phone.locator, '') AS PhoneNumber ,COALESCE(email.locator, '') AS Email FROM dirpartytable party LEFT OUTER JOIN logisticspostaladdress postal ON postal.location = party.primaryaddresslocation AND postal.validto > current_date() -- filters only valid(effective) addresses LEFT OUTER JOIN logisticselectronicaddress phone ON phone.recid = party.primarycontactphone LEFT OUTER JOIN logisticselectronicaddress email ON email.recid = party.primarycontactemail Create table if not exists - use merge This does a copy similar to the above but uses a merge to match the records %%sql -- Step 1: Create Delta table CREATE TABLE IF NOT EXISTS fact3_dirpartytable ( PartyId LONG, Name STRING, ShortName STRING, Country STRING, State STRING, City STRING, Street STRING, PostCode STRING, PhoneNumber STRING, Email STRING ) USING delta; -- Step 2: Create temporary view CREATE OR REPLACE TEMPORARY VIEW temp_dirpartytable AS SELECT party.recid AS PartyId ,party.name AS Name ,COALESCE(party.namealias, '') AS ShortName ,COALESCE(postal.countryregionid, '') AS Country ,COALESCE(postal.state, '') AS State ,COALESCE(postal.city, '') AS City ,COALESCE(postal.street, '') AS Street ,COALESCE(postal.zipcode, '') AS PostCode ,COALESCE(phone.locator, '') AS PhoneNumber ,COALESCE(email.locator, '') AS Email FROM dirpartytable party LEFT OUTER JOIN logisticspostaladdress postal ON postal.location = party.primaryaddresslocation AND postal.validto > current_date() -- filters only valid(effective) addresses LEFT OUTER JOIN logisticselectronicaddress phone ON phone.recid = party.primarycontactphone LEFT OUTER JOIN logisticselectronicaddress email ON email.recid = party.primarycontactemail; -- Step 3: Merge into delta table MERGE INTO fact3_dirpartytable AS target USING temp_dirpartytable AS source ON target.PartyId = source.PartyId WHEN MATCHED THEN UPDATE SET target.Name = source.Name, target.ShortName = source.ShortName WHEN NOT MATCHED THEN INSERT (PartyId, Name, ShortName) VALUES (source.PartyId, source.Name, source.ShortName); This will do an update, insert but will not handle deletes. Create table, Delete and Insert data This creates the table, then deletes the data in full and inserts it all again. %%sql -- Step 1: Create Delta table CREATE TABLE IF NOT EXISTS fact4_dirpartytable ( PartyId LONG, Name STRING, ShortName STRING, Country STRING, State STRING, City STRING, Street STRING, PostCode STRING, PhoneNumber STRING, Email STRING ) USING delta; -- Step 2: Delete data from the Delta table DELETE FROM fact4_dirpartytable; -- Step 3: Create temporary view INSERT INTO fact4_dirpartytable SELECT party.recid AS PartyId ,party.name AS Name ,COALESCE(party.namealias, '') AS ShortName ,COALESCE(postal.countryregionid, '') AS Country ,COALESCE(postal.state, '') AS State ,COALESCE(postal.city, '') AS City ,COALESCE(postal.street, '') AS Street ,COALESCE(postal.zipcode, '') AS PostCode ,COALESCE(phone.locator, '') AS PhoneNumber ,COALESCE(email.locator, '') AS Email FROM dirpartytable party LEFT OUTER JOIN logisticspostaladdress postal ON postal.location = party.primaryaddresslocation AND postal.validto > current_date() -- filters only valid(effective) addresses LEFT OUTER JOIN logisticselectronicaddress phone ON phone.recid = party.primarycontactphone LEFT OUTER JOIN logisticselectronicaddress email ON email.recid = party.primarycontactemail; This runs fast but however not what you may want to do on a regular basis. Create a temporary view and use SinkModifiedOn Create a temporary view within your notebook to use as part of complex queries. This query joins 4 tables together and each table has its own SinkModifiedOn field. I wanted to create a view that gave me the greatest (max) SingModifiedOn date time. This is to later allow me to do an incremental update. CREATE OR REPLACE TEMPORARY VIEW temp_dirpartytable AS SELECT party.SinkModifiedOn AS party_SinkModifiedOn, postal.SinkModifiedOn AS postal_SinkModifiedOn, phone.SinkModifiedOn AS phone_SinkModifiedOn, email.SinkModifiedOn AS email_SinkModifiedOn, GREATEST(party.SinkModifiedOn, postal.SinkModifiedOn, phone.SinkModifiedOn, email.SinkModifiedOn) AS SinkModifiedOn, party.recid AS PartyId ,party.name AS Name ,COALESCE(party.namealias, '') AS SearchName ,COALESCE(postal.countryregionid, '') AS Country ,COALESCE(postal.state, '') AS State ,COALESCE(postal.city, '') AS City ,COALESCE(postal.street, '') AS Street ,COALESCE(postal.zipcode, '') AS PostCode ,COALESCE(phone.locator, '') AS PhoneNumber ,COALESCE(email.locator, '') AS Email FROM dirpartytable party LEFT OUTER JOIN logisticspostaladdress postal ON postal.location = party.primaryaddresslocation AND postal.validto > current_date() -- filters only valid(effective) addresses LEFT OUTER JOIN logisticselectronicaddress phone ON phone.recid = party.primarycontactphone LEFT OUTER JOIN logisticselectronicaddress email ON email.recid = party.primarycontactemail; SELECT * FROM temp_dirpartytable WHERE SinkModifiedOn >= '2024-09-03T02:39:16Z'; This would be good for a transactional table where there are no deletes. You get the last SinkModifiedOn date time field for all the related table. Then filter based on the last run you have in your destination table. You could then do incremental updates. Источник: http://dynamicsnavax.blogspot.com/20...ripts-for.html
