Khue Trinh: Set up & perform Global Search
Источник: http://khue.spaces.live.com/Blog/cns...A0C2!403.entry
============== Set up and start the Data Crawler Go to Basic>Set up>Data Crawler>Table Setup Create a new record, select Address table. Click OK to add all text fields into Text Index. Click on Text Index tab page to check, check the checkbox "Enable Text Index". Go to Basic > Setup > Data Crawler > Data Crawler . On the Overview tab, select a company. On the Crawler tab, if the status is Stopped , select a crawler speed and then click Start crawler . Performing a global search Press CTRL+F to open the Global Search pane. In the Search for field, type the text you are searching for, and then press ENTER. To filter the results of your search, select a category from the Categories list. ![]() ![]() Источник: http://khue.spaces.live.com/Blog/cns...A0C2!403.entry
Опции просмотра | |
