mscrm4ever: CRM 4.0 Creating Interactive Plug-ins
Источник: http://mscrm4ever.blogspot.com/2009/...-plug-ins.html
============== ![]() The Plug-ins model is a truly robust mechanism which makes it very easy to enforce business rules and control the way your organization data flows. However, this model does have a few limitations. One in specific which I find very annoying is the fact you can’t return interactive html to the user and must be satisfied with static textual information. I truly believe ms should consider changing this behavior in their next version. In order to overcome this limitation I made a small yet unsupported modification to the error dialog page that pops up when you throw an Invalid plug-in exception. The dialog resides in inside /CRMWeb/_common/error/dlg_error.aspx In order to make the dialog support HTML messages I added the following function that transforms the ErrorMessage Text to HTML and also added an onload event in the html body tag. function unsupported() { var ErrorMessage = document.getElementById("ErrorMessage"); ErrorMessage.innerHTML = ErrorMessage.innerText; } To test this “theory” I created a simple duplicate detection check on the contact entity first and last name. If a duplicate is found, I construct an HTML error message with a link to the duplicate record and pass it as an InvalidPluginExecutionException parameter. To test this out simply register the plug-in on the contact pre create / update event. using System; using System.Collections.Generic; using System.Text; using Microsoft.Crm.Sdk; using Microsoft.Crm.SdkTypeProxy; using Microsoft.Crm.Sdk.Query; namespace TestPlugin { public class DuplicateHandler : IPlugin { #region IPlugin Members public void Execute(IPluginExecutionContext context) { if (context.InputParameters.Properties.Contains(ParameterName.Target)) { #region Check Duplicate Contact [FirstName LastName] DynamicEntity contact = context.InputParameters.Properties[ParameterName.Target] as DynamicEntity; String firstName = String.Empty; String lastName = String.Empty; if (contact.Properties.Contains("firstname")) { firstName = contact.Properties["firstname"].ToString(); } if (contact.Properties.Contains("lastname")) { lastName = contact.Properties["lastname"].ToString(); } QueryExpression query = new QueryExpression(context.PrimaryEntityName); query.ColumnSet.AddColumn(context.PrimaryEntityName + "id"); ConditionExpression firstCondition = new ConditionExpression(); firstCondition.AttributeName = "firstname"; firstCondition.Operator = ConditionOperator.Equal; firstCondition.Values = new object[] { firstName }; ConditionExpression lastCondition = new ConditionExpression(); lastCondition.AttributeName = "lastname"; lastCondition.Operator = ConditionOperator.Equal; lastCondition.Values = new object[] { lastName }; FilterExpression whereFilter = new FilterExpression(); whereFilter.Conditions.Add(firstCondition); whereFilter.Conditions.Add(lastCondition); whereFilter.FilterOperator = LogicalOperator.And; query.Criteria = whereFilter; ICrmService Service = context.CreateCrmService(true); BusinessEntityCollection resultCollection = (BusinessEntityCollection)Service.RetrieveMultiple(query); #endregion #region Retrieve Duplicate HTML if (resultCollection.BusinessEntities.Count > 0) { contact dupContact = resultCollection.BusinessEntities[0] as contact; String linkStyle = "text-decoration:underline;color:blue;"; String contactUrl = String.Format( "{3} {4}" , linkStyle, context.OrganizationName, dupContact.contactid.Value.ToString(), firstName, lastName ); String errorMessage = String.Format("Duplicate Contact: {0}",contactUrl); throw new InvalidPluginExecutionException(errorMessage); } #endregion } #endregion } } } Источник: http://mscrm4ever.blogspot.com/2009/...-plug-ins.html
Опции просмотра | |
