mscrm4ever: Creating a Network Path Text Control
Источник: http://mscrm4ever.blogspot.com/2009/...t-control.html
============== ![]() Dynamics supports several types of text fields. One type which is not available in the current version is a text field that supports a UNC path (\\) or a network drive (Y:) to a shared folder on the server or on the user local machine. The following example converts a regular text field into a network path control. The control works in conjunction with an Explorer page which contains an IFRAME to the actual network share. The Explorer(.aspx) should be deployed in the ISV folder. When the user double clicks on the field value a window is opened pointing to the shared folder. The control also provides a comfortable API for managing extra query parameters, changing control style, changing explorer window features and setting an initial network path. The last can be a handy feature if you require the explorer to point to an account personal folder within a shared file system tree. Here is the Explorer.aspx implementation: Dynamics File Explorer .header { background-color:#639ace; padding-left:10px; color:White; font-size:x-large; font-family:arial; height:30px; } .iframe { border:1px solid #94b2de; height:100%; width:100%; } body { margin:0px; border:0px solid; } File Explorer The following script should be added to the entity onload event: // JScript File function OnCrmPageLoad() { var networkPath = new NetworkPath("fax"); //Example Add query string parameter networkPath.Params.Add("test","1"); //Example Remove query string parameter networkPath.Params.Remove("test"); //Example change control default style networkPath.Style.Add("color","red"); //Transform the text field into a network path field networkPath.Transform(); } function NetworkPath(baseControlId) { nk = this; nk.ID = baseControlId; nk.Control = document.all[nk.ID]; /* Default Path */ nk.Path = "\\\\127.0.0.1\\Files"; //default path nk.Window = null; /* File Explorer Features (window.open)*/ nk.Features = new Dictionary(",","="); /* If you wish to extend the Explorer.aspx and add more querystring parameters */ nk.Params = new Dictionary("&","="); /* Network path control additional styling rules */ nk.Style = new Dictionary(";",":"); nk.Transform = function() { if (nk.Control) { /* Assign default path if control value is empty */ if (nk.Control.DataValue == null) { nk.Control.DataValue = nk.Path; } nk.Control.title = "Double Click to Open Network Explorer"; /* Default Window Settings */ if (!nk.Features.Exist("width")) { nk.Features.Add("width",700); } if (!nk.Features.Exist("height")) { nk.Features.Add("height",400); } if (!nk.Features.Exist("resize")) { nk.Features.Add("resize","yes"); } if (!nk.Features.Exist("toolbar")) { nk.Features.Add("toolbar","no"); } if (!nk.Features.Exist("menubar")) { nk.Features.Add("menubar","no"); } if (!nk.Features.Exist("titlebar")) { nk.Features.Add("titlebar","no"); } /* Attach validation to change and save events */ nk.Control.attachEvent( "onchange" , nk.Validate ); crmForm.attachEvent( "onsave" , nk.Validate ); /* Adjust control style */ nk.Style.Add("text-decoration","underline"); if (!nk.Style.Exist("color")) { nk.Style.Add("color","blue"); } nk.Style.Add("cursor","hand"); nk.Control.style.cssText += ";" + nk.Style.ToString(); /* Add double click functionality */ nk.Control.ondblclick = nk.Open; } } nk.Validate = function() { if (nk.Control.DataValue == null) { return true; } /* validate \\ unc path or a netwrok drive Y: */ var regex = new RegExp("^(\\\\|[a-zA-Z]:)"); if (!regex.exec(nk.Control.DataValue)) { alert("Invalid Network Path or Drive"); return (event.returnValue = false); } return true; } nk.Open = function() { if (nk.Control.DataValue != null) { nk.Window = window.open( SERVER_URL + "/isv/explorer.aspx?path=" + nk.Control.DataValue + nk.Params.ToString() , "" , nk.Features.ToString()); } } nk.Close = function() { nk.Window.close(); } /* Key Value Pair Collection */ function Dictionary(sep,delim) { this.list = []; this.Seperator = sep; this.Delimiter = delim this.Add = function(key , value) { this.list[key] = value; } this.Remove = function(key) { this.list[key] = ""; } this.Exist = function(key) { return this.list[key] != null && this.list[key] != ""; } this.ToString = function() { var result = new StringBuilder(); result.Append(this.Seperator); for(var key in this.list) { if (this.list[key]!="") { result.Append(key).Append(this.Delimiter); result.Append(this.list[key]).Append(this.Seperator); } } var tmp = result.ToString(); return tmp.substring(0,tmp.length-1); } } function StringBuilder() { this.data = []; this.Append = function(text) { this.data[this.data.length] = text; return this; } this.Reset = function() { this.data = []; } this.ToString = function() { return this.data.join(""); } } } OnCrmPageLoad(); Источник: http://mscrm4ever.blogspot.com/2009/...t-control.html
Опции просмотра | |
