Старый 01.04.2024, 15:12   #1
crmtipoftheday: Tip #1455: Experiment with parallel branches
Источник: https://crmtipoftheday.com/1455/expe...allel-branches
While experimenting in a flow trying to find that elusive expression or action, I often catch myself doing this:
The problem is, of course, I don’t bother setting Run After conditions and the result often looks like this:
Now I have to edit, figure out what’s wrong, run again and again as I didn’t get to even try three other steps. If you find yourself doing the same mind-numbing experimental activities, make it a habit to use parallel branches!
Add a parallel branch or two and rearrange the existing flow.
The execution nails one of the actions as a solution in a single run!
You can continue branching out, of course, on any level:
PS. Credit where credit’s due: juggling parallel branches is much easier in the new Power Automate editor.
PPS. Use parallel branches for production runs as well. Don’t tell anyone but executing things in parallel is usually faster.
The post Tip #1455: Experiment with parallel branches appeared first on Power Platform & Dynamics CRM Tip Of The Day.
crmtipoftheday: Tip #1451: Aggregates in Power Automate Blog bot Dynamics CRM: Blogs 0 26.03.2024 03:40
crmtipoftheday: Tip #1402: Why you should not use Microsoft Lists/SharePoint Lists for business-critical Power Apps Blog bot Dynamics CRM: Blogs 0 17.02.2021 15:12
crmtipoftheday: Tip #1100: Consider using parallel workflows instead of if-then statements Blog bot Dynamics CRM: Blogs 0 09.04.2018 05:11
crmtipoftheday: Tip #1095: Add percentage labels to pie charts Blog bot Dynamics CRM: Blogs 0 02.04.2018 04:16
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
Часовой пояс GMT +3, время: 03:55.
