Старый 06.12.2010, 16:11   #1
emeadaxsupport: How to trace AIF Web service SOAP message
Источник: http://blogs.msdn.com/b/emeadaxsuppo...p-message.aspx
For troubleshooting reasons sometimes is needed what exactly SOAP message is sent to AIF service. So we get a lot of questions how can we track such a message. The problem is not directly connected to Dynamics AX because using following method you can track every service included AIF Web service.
The easy way to get SOAP message can be:
1. Create C# client as described in: http://msdn.microsoft.com/en-us/library/cc652581.aspx
2. Then add traces information to app.config created automatically for your application (as mentioned http://bloggingabout.net/blogs/chilb...ice-trace.aspx). So my app.config look following:
3. Run C# program in C:\logs\ there will be file Log.svclog created
4. In C:\Program Files\Microsoft SDKs\Windows\v6.0A\Bin you can find SvcTraceViewer.exe you can just double click it to open then you can load the log created.
5. You will see all tracing information and also SOAP envelope
--author: Czesława Langowska --editor: Czesława Langowska --date: 06-12-2010
axaptasource: Tip How to Trace a Call to an AIF Web Service Blog bot DAX Blogs 0 26.11.2010 20:11
daxdilip: Tip How to Trace a Call to an AIF Web Service Blog bot DAX Blogs 0 26.11.2010 00:12
emeadaxsupport: Creating an MSMQ message that can be consumed by AX AIF process Blog bot DAX Blogs 0 26.04.2010 19:05
emeadaxsupport: What changes are required if we change the Business Connector Proxy used by AX 2009 Generated AIF Web services Blog bot DAX Blogs 0 29.03.2010 15:05
Часовой пояс GMT +3, время: 20:26.
