Старый 14.09.2012, 13:11   #1
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting: How to translate parameters values
Источник: http://blogs.msdn.com/b/axsupport/ar...rs-values.aspx
Sometime ago I run into following problem.
  1. I followed step provided in msdn article: http://msdn.microsoft.com/en-us/library/gg724119.aspx
  2. After that I have generated Precision Design and I have edited it to display parameter values with which the report was run:
3. I deployed report and created display menu item and opened the report
- I specified * for account number parameter
I printed report in EN-US language – looks fine:
I printed report in NL-BE language – parameters are not translated:
To solve the problem we need to do a little more of development:
  1. For parameters which are different that NoYes enum. We can translate parameter using: http://msdn.microsoft.com/en-us/library/ee873271.aspx
a. add a new dataset:
b. use the new created dataset to fill the value of the parameter Customer_CustAccountStatement
c. modify the parameter expression from Value to Label
Then this parameter will translated correctly.
2. For parameter which use NoYes enum we can use expression:
=Microsoft.Dynamics.Framework.Reports.BuiltInMethods.GetEnumLabelFromValue("NoYes", IIF(Parameters!Customer_InclTax.Value.Equals("Yes"),1,0), parameters!AX_RenderingCulture.Value, parameters!AX_UserContext.Value)
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
emeadaxsupport: Dynamics AX 2012 Reporting: How to specify new design for Sales order confirmation Blog bot DAX Blogs 0 24.05.2012 14:11
emeadaxsupport: Microsoft Dynamics AX 2012 Enterprise Portal: How to provider access for user to be able to only Personalize Page on SharePoint 2010 Blog bot DAX Blogs 0 13.12.2011 22:11
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting Services – Scale-out deployments Blog bot DAX Blogs 0 28.11.2011 00:14
dynamics-ax: Modeling the world, with Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.01.2011 09:11
Часовой пояс GMT +3, время: 00:13.
