Старый 27.02.2013, 21:11   #1
Axilicious:AX2012 R2 : DB Sync – Failed to create a session
Источник: http://www.ksaelen.be/wordpresses/dy...ate-a-session/
Thanks to a Kevin Roos, for spending the time to look into this one!
We have been seeing the following error lately in AX2012 R2:
Failed to create a session; confirm that the user has the proper privileges to log on to Microsoft Dynamics
A closer look into this learned that this is linked to the new partitions feature.
It seems the UserInfo table is not correctly updated and the partition administrator is not updated correctly when you restore an existing DB or the Demo database.
To fix this, you can do the following.
  • Stop the AOS
  • Restore the database again
  • Start the AOS
  • Start a client and complete the partition initialiasation checklist
  • Close the client and execute the script below on the SQL database
  • Restart the client and reimport your license (if you were restoring the Microsoft demo data, the demo license is back in there)
  • Then compile / generate CIL / DB sync and you should be on track again!
The script for updating the UserInfo inforation is as follows:
DECLARE @NetworkDomain nvarchar(255); DECLARE @NetworkAlias nvarchar(80); DECLARE @SID nvarchar(124); DECLARE @InitialPartition BIGINT; SELECT @InitialPartition=Recid FROM PARTITIONS WHERE PARTITIONKEY=N'Initial' SELECT @NetworkAlias=NETWORKALIAS,@NetworkDomain=NETWORKDOMAIN,@SID=SID FROM USERINFO WHERE PARTITION=@InitialPartition AND ID = N'Admin' UPDATE USERINFO SET NETWORKDOMAIN=@NetworkDomain,NETWORKALIAS=@NetworkAlias,SID=@SID WHERE PARTITION != @InitialPartition AND ID = N'Admin'
ukax: Dynamics AX2012 R2 Launches!!!! Blog bot DAX Blogs 0 04.12.2012 19:11
emeadaxsupport: AX2012 Retail: MS Sync Service fails to synchronize transactions from offline database Blog bot DAX Blogs 0 15.08.2012 09:11
axblog4u: Dynamics AX2012: Create Custom Service using X++ Blog bot DAX Blogs 0 24.01.2012 21:11
Failed to create user session on the server Serj187 DAX: Администрирование 2 07.06.2011 14:34
Failed to create user session on the server monk DAX: Администрирование 5 01.09.2009 12:16
Часовой пояс GMT +3, время: 20:42.
