Старый 30.05.2013, 13:05   #1
Swordec is offline
Swordec
Пакетная печать документов в Excel
Microsoft Dynamics Ax 2012
Добрый день. Кто нибудь настраивал пакетную печать документов в Excel?
При попытке сделать разноску накладной и затем вывести ее на печать с помощью пакетной обработки, выдает ошибку:
Microsoft.Dynamics.Ax.Xpp.InvalidRemoteCallException: Exception of type 'Microsoft.Dynamics.Ax.Xpp.InvalidRemoteCallException' was thrown.
at Dynamics.Ax.Application.XMLExcelReport_TORG12_RU.construct()
at Dynamics.Ax.Application.SalesPurchReport_Invoice_RU.Run() in SalesPurchReport_Invoice_RU.run.xpp:line 12
at Dynamics.Ax.Application.SalesPurchReport_RU.executeWithPrintMgmtTorg12M15(Args _args, PrintMgmtPrintSettingDetail _settingDetail, Int64 _recordId) in SalesPurchReport_RU.executeWithPrintMgmtTorg12M15.xpp:line 50
at Dynamics.Ax.Application.NonSSRSPrintMgmtAdapter.Executenonssrsreport(PrintMgmtPrintSettingDetail _setting) in NonSSRSPrintMgmtAdapter.executeNonSSRSReport.xpp:line 14
at Dynamics.Ax.Application.NonSSRSPrintMgmtAdapter.Outputreports() in NonSSRSPrintMgmtAdapter.outputReports.xpp:line 14
at Dynamics.Ax.Application.SalesInvoiceNonSSRSPrintMgmtAdapter.Runprintmgmt() in SalesInvoiceNonSSRSPrintMgmtAdapter.runPrintMgmt.xpp:line 43
at Dynamics.Ax.Application.NonSSRSPrintMgmtAdapter.runPrintMgmtNonSSRS(PrintMgmtDocumentType _printMgmtDocumentType, Args _args) in NonSSRSPrintMgmtAdapter.runPrintMgmtNonSSRS.xpp:line 25
at Dynamics.Ax.Application.SalesInvoiceController.main(Args _args) in SalesInvoiceController.main.xpp:line 21
at SalesInvoiceController::Main(Object[] )
at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeStaticCall(Type type, String MethodName, Object[] parameters)
at Dynamics.Ax.Application.MenuFunction.Run(xArgs _args, Boolean ) in MenuFunction.run.xpp:line 76
at Dynamics.Ax.Application.CustInvoiceJour.Printjournal(SalesInvoiceJournalPrint journalPrint, RecordSortedList journalList, NoYes copy, NoYes parmPrintFormLetter, NoYes parmPrintAcceptanceReport, NoYes parmPrintBillOfLading, NoYes parmPrintInventBaileeReport, NoYes parmPrintTransportInvoice, Boolean , Boolean , Boolean , Boolean , Boolean , Boolean , Boolean , Boolean ) in CustInvoiceJour.printJournal.xpp:line 104
at Dynamics.Ax.Application.SalesInvoiceJournalPrint.Doprint() in SalesInvoiceJournalPrint.doPrint.xpp:line 7
at Dynamics.Ax.Application.FormletterJournalPrint.Printjournal(Set _journalList) in FormletterJournalPrint.printJournal.xpp:line 34
at Dynamics.Ax.Application.SalesInvoiceJournalPrint.Printjournal(Set _journalList) in SalesInvoiceJournalPrint.printJournal.xpp:line 13
at Dynamics.Ax.Application.FormletterService.Printjournal() in FormletterService.printJournal.xpp:line 33
at Dynamics.Ax.Application.FormletterService.Printout() in FormletterService.printOut.xpp:line 11
at Dynamics.Ax.Application.FormletterService.Endposting(Printout _printout) in FormletterService.endPosting.xpp:line 14
at Dynamics.Ax.Application.FormletterService.Endpostingmultithread() in FormletterService.endpostingMultithread.xpp:line 25
at Dynamics.Ax.Application.FormletterServiceEndBatchTask.Run() in FormletterServiceEndBatchTask.run.xpp:line 12
at Dynamics.Ax.Application.BatchRun.runJobStaticCode(Int64 batchId) in BatchRun.runJobStaticCode.xpp:line 54
at Dynamics.Ax.Application.BatchRun.runJobStatic(Int64 batchId) in BatchRun.runJobStatic.xpp:line 13
at BatchRun::runJobStatic(Object[] )
at BatchIL.taskThreadEntry(Object threadArg)
Старый 30.05.2013, 13:26   #2
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
OXML классы используют клиентский класс WinApi а сейчас Batch Server работает без клиента.
Нужно править код.
За это сообщение автора поблагодарили: Swordec (1).
Старый 30.05.2013, 18:36   #3
gl00mie is offline
gl00mie
3,684 / 5803 (201) ++++++++++
Он уже пятый год как работает без клиента (или когда там официально 2009-я вышла).
Нужно править код.
Но это не будет сделано, пока кто-нить не напишет официальный запрос в поддержку?..
Старый 31.05.2013, 09:04   #4
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
Запрос поможет повысить приоритет такой работы так как подтверждает, что сценарий реально используется клиентами.
Старый 31.05.2013, 09:50   #5
lev is offline
lev
Ищущий знания...
Аватар для lev
1,723 / 491 (20) +++++++
Я правильно понимаю, что сценарии пишутся с расчетом, что клиенты их использовать не будут?
Мне кажется любой реализованный сценарий должен корректно выполняться. Если считается, что все равно его использовать не будут, тогда не надо его реализовывать.
P.S. напомнило Первый тест-драйв Lada Kalina 2
в частности:
На тестовом полигоне при прохождении «змейки» у коллеги заклинил руль – представители завода заявили, что с потребителем такого не случится, он, мол, не будет крутить руль до упора на больших скоростях
С Уважением,
Елизаров Артем
Последний раз редактировалось lev; 31.05.2013 в 10:16.
Старый 31.05.2013, 12:58   #6
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
Я не про это
- Может быть что сценарий не написан, но у клиента он возникает
- Может быть что сценарий написан, но в реализации ошибка
В этом случае возникает вопрос (упрощая), какую из таких ошибок править первой. Для этого надо расставлять приоритеты.
Возможна ситуация, когда функциональность пока никем не используется.
Регистрация ошибки в позволяет показать, что функциональность используется, а также сообщить важность самой ошибки.
в частности:
Я бы сказал, что в данном случае официально обратиться к представителю завода можно посредством регистрации ошибки. К тому же вы обратитесь в отдел, который официально отвечает за поддержку пользователей.
Старый 11.06.2013, 13:47   #7
Swordec is offline
Swordec
Добрый день.
С помощью visual studio я попытался дебажить пакет, чтобы определить где используется WinApi и заменить на WinApiServer. Когда в методе run класса SalesPurchReport_Invoice_RU доходит до строки "reportPrint = XMLExcelReport_TORG12_RU::construct();"(рис. 1), то при нажатии на клавишу F11 я должен попасть в метод construct класса XMLExcelReport_TORG12_RU, но оно пропускает это и переходит в метод runJobStaticCode класса BatchRun(рис. 2).
Я попытался поставить точку останова в методе construct класса XMLExcelReport_TORG12_RU, возникает ошибка "The reakpoint will not currently be hit. No symbols have been loaded for this document."(рис.3).
Старый 11.06.2013, 13:54   #8
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
Изменили ли вы runOn: client у класса XMLExcelReport_TORG12_RU?
Последний раз редактировалось belugin; 11.06.2013 в 13:58.
Старый 21.06.2013, 11:29   #9
Swordec is offline
Swordec
System.NullReferenceException: Object reference not set to an instance of an object.
   at Microsoft.Dynamics.Ax.Xpp.Set.elements()
   at Dynamics.Ax.Application.FormletterJournalPrint.Printjournal(Set _journalList) in FormletterJournalPrint.printJournal.xpp:line 26
   at Dynamics.Ax.Application.FormLetterServiceController.Afteroperationprint() in FormLetterServiceController.afterOperationPrint.xpp:line 20
   at Dynamics.Ax.Application.FormLetterServiceController.Afteroperationbody() in FormLetterServiceController.afterOperationBody.xpp:line 6
   at Dynamics.Ax.Application.SalesFormLetter.Afteroperationbody() in SalesFormLetter.afterOperationBody.xpp:line 6
   at Dynamics.Ax.Application.SalesFormLetter_Invoice.Afteroperationbody() in SalesFormLetter_Invoice.afterOperationBody.xpp:line 6
   at Dynamics.Ax.Application.FormLetterServiceController.Afteroperation(SysOperationExecutionMode _executionMode, AifAsyncResult _asyncResult) in FormLetterServiceController.afterOperation.xpp:line 7
   at Dynamics.Ax.Application.SysOperationServiceController.Run() in SysOperationServiceController.run.xpp:line 70
   at Dynamics.Ax.Application.FormLetterServiceController.Run() in FormLetterServiceController.run.xpp:line 3
   at Dynamics.Ax.Application.SalesFormLetter.Run() in SalesFormLetter.run.xpp:line 72
   at Dynamics.Ax.Application.SalesFormLetter_Invoice.Run() in SalesFormLetter_Invoice.run.xpp:line 6
Последний раз редактировалось Swordec; 21.06.2013 в 11:51.
Старый 21.06.2013, 16:14   #10
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
1. Если отключит Il то работает?
2. Попробуйте поставить точку останова в vs
Старый 21.06.2013, 18:51   #11
Swordec is offline
Swordec
В обычном режиме все нормально, но в пакете в методе printJournal класса FormLetterJournalPrint доходит до строк
 if (journalList.len() > 0
        // <GEERU>
         || (SysCountryRegionCode::isLegalEntityInCountryRegion([#isoRU])
         && factureList.elements() > 0)
        // </GEERU>
и vs выдает ошибку: "Object reference not set to an instance of an object."
Последний раз редактировалось Swordec; 21.06.2013 в 18:55.
ax2012, cil, excel, open xml, баг, ошибка, пакетная обработка, пакетный сервер
Двухсторонняя печать в Excel EfimV DAX: Программирование 2 15.11.2010 13:26
Печать страниц Excel на отдельные листы kuvg DAX: Программирование 3 02.08.2010 10:55
Запрет на печать и сохранение документов doc, xls. 3oppo DAX: Программирование 23 27.05.2010 17:07
Печать документов по Заказам, Закупкам Swetik DAX: Функционал 8 11.04.2008 20:07
Печать отчета в Excel. Axapta 3.0 Fedr Kuzmich DAX: Функционал 2 19.05.2004 18:26
Часовой пояс GMT +3, время: 16:11.
