Старый 31.07.2013, 03:41   #1
goshoom: AX2012 R2 Demo V3.0
Источник: http://dev.goshoom.net/en/2013/07/ax...2-demo-v3-0-2/
Microsoft recently released new virtual machines with preconfigured AX2012 R2 (and a lot of other stuff): Microsoft Dynamics AX 2012 R2 Solution Demo Package V3.0.
I’ve already installed the main machine and I would like to share two warnings:
  1. If you run Hyper-V 2.o (Windows Server 2008), you can’t import the virtual machine – you have to create a new one and use the provided virtual disk. See Setup Instructions document for details.
  2. It requires a lot of resources. I had no troubles on my machine with the previous version, but this one immediately took all resources, including complete capacity of 4 processors (2.4 GHz). Fortunately, killing SharePoint helped me to get to some normal numbers.
    It’s also obvious that 6 GB of RAM (that successfully I used for the previous version) aren’t sufficient anymore – Microsoft recommends 16 GB.
ukax: Microsoft Dynamics AX 2012 R2 Solution Demo Package V3 Blog bot DAX Blogs 17 04.09.2013 12:54
Я хочу поставить AX2012 R2 с Российским функционалом и с нуля. Ошибка при установке Sarvan DAX: Администрирование 21 28.06.2013 20:24
axtools: AX2012 R2 hotfix available to improve compile speed Blog bot DAX Blogs 1 01.05.2013 03:53
Axilicious:AX2012 R2 : DB Sync – Failed to create a session Blog bot DAX Blogs 0 27.02.2013 21:11
ukax: Dynamics AX2012 R2 Launches!!!! Blog bot DAX Blogs 0 04.12.2012 19:11
Часовой пояс GMT +3, время: 18:15.
