Старый 24.06.2004, 02:27   #1
Leon is offline
Leon
Navision 2.5 SQL option. Error during database creation
Hi, please could anyone help me to solve a problem. I have Navision 2.5. I ‘d like to move to SQL Server option. I have proper license to do this.
My OS is Windows 2000 and I have SQL 2000 Enterprise edition. I have only American English and nothing else installed.
I use menu File->Database-> New->General tab to crate a new database In navision. I have following error after I input database name on General tab.
The Current ANSI or OEM code page on you computer does not match the 0 code page on the SQL server. You must ensure that either the ANSI or OEM code page matches the server code page.
My default server collation is SQL_Latin1_General_CP_CI_AS.
Thank you very much for your help,
Vic
Старый 28.07.2006, 17:17   #2
.rejector. is offline
.rejector.
Аватар для .rejector.
35 / 10 (1) +
Возникла похожая проблема, только при открытии базы.
Версия 2,60 на SQL. Клиента запускаю на сервере, там по определению кодовая страница одна и та же.
Server collation: Cyrillic_General_CI_AS
Какие версии есть?
Старый 02.08.2006, 12:33   #3
e39-528i is offline
e39-528i
try to use MS SQL 7.0.
imho, navision 2.5 doesn t work with sql 2000.
system tables of sql 2000 is different from MS SQL 7.0. - this is the source of error.
Navision Database Server c0der NAV: Администрирование 2 27.05.2005 22:37
Navision - SQL Server. Открытие БД. Mary NAV: Администрирование 0 30.03.2005 19:03
Navision Database Server Mad_lena NAV: Администрирование 0 28.12.2004 04:09
Purchase receipt. Posting problem. Navision 2.6. Migration to SQL Server. Leon NAV: Функционал 1 26.08.2004 11:34
DateTime в SQL Server Option Dimon NAV: Администрирование 1 12.04.2004 11:00
Часовой пояс GMT +3, время: 09:57.
