Старый 21.07.2009, 10:05   #1
25,565 / 848 (80) +++++++
lcash: Using document handling to add image in Demo VM
Источник: http://blogs.msdn.com/lcash/archive/...n-demo-vm.aspx
Is you are using the AX2009 Refresh 2 demo VM and are using document handling this note will interest you. When you try to add a image, for file attachment you will get an error about “no valid runable code”.
It is a small change :
1. Press CRTL+D to got to the AOT.
2. Expand Classes
3. Locate the DocuActionArchive class
4. Double click on the add method.
5. Move the line of code FormRun parentForm above the function.
6. Click the Save button.
Then close the code window and AOT and you will be able to add the image etc in document handling.
Cheers
Lachlan
Original post at http://blogs.msdn.com/lcash
chrisfie: Microsoft Dynamics AX 2009 and Microsoft Project Server 2007 Demo Image Blog bot DAX Blogs 2 03.07.2009 20:05
lcash: Entering dates (2006) or no access to development in Refresh1 VM Blog bot DAX Blogs 0 03.07.2009 08:05
Ruslan Goncharov: How to add a document into AX programmically? (Document handling) Blog bot DAX Blogs 0 29.12.2007 19:50
dax-lessons: Document Handling in AX - setup and Example Blog bot DAX Blogs 0 27.08.2007 23:00
Axapta Lessons: FORM SalesTable (3): Add a document to the button Posting Blog bot DAX Blogs 0 28.10.2006 18:22
Часовой пояс GMT +3, время: 07:10.
