#22 |
Если кому интересно, вот наткнулся на информацию о резервировании в официальных, так сказать, источниках (расширенный тренинг по производству).
" The serial number and batch number dimensions can be set up as either primary or secondary dimensions. This affects the way items are reserved/re-reserved. If an item is set up with the batch number dimension as a primary dimension, it will mean that when ordered receipts are reserved, no re-reservations will be made if there are physical receipts, and that the production will NOT be started until the appropriate batch has been received even if other batches of the same items are physically received. If, on the other hand, an item is set up with the batch number dimension as secondary dimension, re-reservation is made when there is physical item receipt, as long as this is appropriate in relation to the net profile requirement for the item. " Правда, толи я не понял, толи не смог повторить...
С уважением, glibs® |
