Исправлено в sp3:
GB-249-622-DEBN Import/Export problem in Axapta 2.5 and 3.0. Previously, if you changed a field property on a form, then exported it, and then imported it again, the change would be ignored, despite being preserved in the export file. The problem would only occur if no method existed on that particular field. The error has been corrected. |
| За это сообщение автора поблагодарили: vallys (1). | |
Developer
Сообщение от Ax1D
Исправлено в sp3:
GB-249-622-DEBN Import/Export problem in Axapta 2.5 and 3.0. Previously, if you changed a field property on a form, then exported it, and then imported it again, the change would be ignored, despite being preserved in the export file. The problem would only occur if no method existed on that particular field. The error has been corrected. Решение № 1 (для SP2) - перекрывать метод (любой) у поля датасоурса с измененным свойством. Решение № 2 (для SP2) - определять свойство поля датасоурса в коде. Последний раз редактировалось vallys; 06.03.2006 в 10:22. |
